Eastern Beaver Headlight Relays - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 29Likes
post #1 of 50 Old 05-31-2017, 06:19 PM Thread Starter
Highwayman2016's Avatar
Just a post to say how easy it was to install the headlight relay kit on my 2014 Wee. Here are a couple pictures to show the difference. beforeafter. Brighter?
Big B and kd70qc like this.
2014 Wee Strom
Highwayman2016 is online now
post #2 of 50 Old 05-31-2017, 07:44 PM
Bogfarth's Avatar
A far simpler way is to aim your headlights at the inside of a garage door. Mine were notably brighter with the relays than without.
Highwayman2016 likes this.
Being slow doesn't make a boring bike. I had a R1 which I thought was boring. Boring is a bike that doesn't speak to you. If you like what your bike is saying let it's voice take you to far flung places. - Vertical C
Bogfarth is offline
post #3 of 50 Old 05-31-2017, 09:33 PM
kd70qc's Avatar
Dare I ask, how long it took you to install?
2015 DL650XT w/ factory Suzuki/Motech side cases and engine guard.
First farkle - Motech center stand
Suzuki handguards
Augustus Wind Deflectors
Fat, foamy grips
Givi AirFlow windscreen
Go-Cruise throttle lock
JD Astar 1260 lumen LED tail light bulb
Suzuki (SW Motech) Top Case
Hyde Racing skid plate
Adventuretech kickstand foot, fork brace and fender raising kit.
Zita 26mm up / 20mm back risers
Sit and Fly Seat Net
So God created man in His own image; in the image of God He created him; male and female He created them. Genesis 1:27
kd70qc is offline
post #4 of 50 Old 05-31-2017, 09:37 PM
Supatramp's Avatar
Originally Posted by Highwayman2016 View Post
Just a post to say how easy it was to install the headlight relay kit on my 2014 Wee. beforeafter. Brighter?
I bought a relay kit off the auction sight for $10.50. It took a couple of weeks to get here from China, but seems to work fine.
Now when I pull behind a Corvette, they melt.
Supatramp is offline
post #5 of 50 Old 05-31-2017, 10:47 PM
Administrator
I am about to order mine up soon, put it off long enough.
Supatramp likes this.
2015 DL650 XT "Drill"
Big B is online now
post #6 of 50 Old 05-31-2017, 10:53 PM
Supatramp's Avatar
Yep, you'll ask yourself, "why did I wait so long"
Big B likes this.
post #7 of 50 Old 05-31-2017, 11:05 PM
Administrator
Have a big/long West trip coming up in July, and not frying my wiring or having other failures related to Suzuki's total negligence, will be one less thing I need to worry about.
Big B is online now
post #8 of 50 Old 06-01-2017, 12:02 AM
Bogfarth's Avatar
I stripped the EB relay kit from my old '09 Wee prior to trading it in, as the stealership declined to proffer a higher value for farkles v. no farkles. Removing the harness? 15 minutes. Installing it on my '15 XT was only tricky in one respect: routing the wires under the tank without popping the tank off the bike. A straight piece of 14ga solid wire threaded things nicely under the tank and right back to the battery. Total time was about 45 minutes, including the zip ties to tidy things up. Headlights are brighter, switch gear and connectors are protected, and if you squirt a little dielectric grease on the relay contacts they should last longer than the bike.
Bogfarth is offline
post #9 of 50 Old 06-01-2017, 12:11 AM
Ypu installed the H4 headlight relays without the pc8 box, am I right?
Thks
Patrick
SwampRider-ECU is offline
post #10 of 50 Old 06-01-2017, 07:59 PM
Bogfarth's Avatar
Yep. My '09 had a 3CS from EB, so I had to snip the connector off and replace it with battery rings to fit the Glee.
Bogfarth is offline
Human Verification
