Luggage frame and back rest - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 4Likes
post #1 of 14 Old 05-17-2017, 08:35 AM Thread Starter
DavidL's Avatar
My new 2015 DL650 adv came with a luggage frame and side luggage. I am confused about the Trunk Box Luggage Rack Mount.
- Is it a universal mount or would I need an adapter for the various top boxes out there?
- Can that mounting plate come off and the rubber cover be put back on without having to remove the entire luggage frame?
- If money wasn't and object, I'd have a Corbin seat and backrest, however, that is not in the cards. What are my options for a passenger backrest for my wife? She only rides with me occasionally and doesn't have a jacket with back protection.
Thanks
2015 DL650A, Tusk Handlebar Riser - 30mm, SW-MOTECH Center stand, Adventure Tech mirror extenders with ram ball.
DavidL is offline
post #2 of 14 Old 05-17-2017, 09:27 AM
Xirdneh82's Avatar
I am in the exact same boat as you. The wife is used to having a backrest and really wants one on the Strom. I have the exact same OEM bracket and was just going to order the yescom 30l tail box from Amazon for $36.95. It has a backrest pad that comes with it and looks like the brackets would mount to the OEM bracket. If it doesn't pan out, oh well, I'm only out $40.
Sent from my SM-T580 using Tapatalk
Xirdneh82 is offline
post #3 of 14 Old 05-17-2017, 09:28 AM
Xirdneh82's Avatar
To answer one of your questions, I do not think the rubber pad can go on unless you remove the pannier mounting bracket as well.
post #4 of 14 Old 05-17-2017, 09:54 AM
Moderator++
Permanently mounted top boxes can be attached to that top plate. Quick release type cases need an adapter plate. Most top box users have found the just using the top box for a back rest with a jacket having a back pad works best. Boxes with a pad included make the pad intrusive to the passenger.
kd70qc likes this.
greywolf is online now
post #5 of 14 Old 05-17-2017, 10:05 AM
Fox
Fox's Avatar
This has been my experience. I bought the backrest for my Shad topcase, but my girlfriend prefers to just lean against the case itself because it would otherwise pitch her forward slightly. Her jacket's back pad is enough.
Fox is offline
post #6 of 14 Old 05-17-2017, 07:41 PM Thread Starter
DavidL's Avatar
Thanks for all of the responses. I just ran into another snag. My wife and I are both 61. She has an artificial hip and can't swing her leg over the side bags. I took them off and she barely got her leg around to sit and getting off was worse. If I have a back rest, her leg won't clear it. My old Nomad was so low that it wasn't an issue. I know we are an ageing community, has anyone dealt with this issue before?
DavidL is offline
post #7 of 14 Old 05-17-2017, 09:01 PM
Yah, we got a side car and until the wife had the second hip replaced we terrorized the west.
My Luftmeister trunk had a back rest on the BMW. The JC Whitney top box has a faux pad that may provide some level of comfort, especially if you are wearing a moto jacket with a back pad.
DavidL likes this.
post #8 of 14 Old 05-17-2017, 09:28 PM
Mounting and dismounting can be a bit tricky, especially with luggage on the bike. You may need to let her get on first and off second. We're a bit behind you in years but my wife isn't as agile as she once was. We use this method when we have the panniers on the bike.
As stated, for a backrest use a trunk. I use the Kappa KGR52 top case. My wife doesn't need a padded jacket for comfort due to the slightly rounded smooth hinge area. Unfortunately this case uses a special Givi monokey rack.
notacop and DavidL like this.
wingstrom is offline
post #9 of 14 Old 05-18-2017, 10:50 AM
Slickrock's Avatar
Maybe get a quick release trunk and take it off before she gets on so it isn't in the way when she gets on? Does she use the foot peg to get a little bit more height while mounting?
Just some before work forum thoughts.
Slickrock (Dan)
2013 Dl650A and 1983 Honda XL600r Thumper. Lower end of Central Valley, CA.
Slickrock is offline
post #10 of 14 Old 05-18-2017, 01:28 PM Thread Starter
DavidL's Avatar
Yes, she uses the foot peg. The problem with a quick release trunk is I would have to be off of the bike to take it on and off. She could use a mounting block but it would be kind of hard to carry with us
DavidL is offline
Human Verification
