rear tire hugger - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
  • 1 Post By notacop
  • 1 Post By Big B
post #1 of 10 Old 02-14-2017, 09:50 PM Thread Starter
rear tire hugger
Anybody install a hugger on the rear? If so does it help with the crude much? I just bought the fender extender for the front, was thinking about the rear now. I always get crap sprayed clean up on my top box.
turtlespeed is offline
post #2 of 10 Old 02-15-2017, 06:50 AM
spike55_bmw's Avatar
Seems like only two choices (GIVI & Puig) unless you want to make your own. Pricey too.
spike55_bmw is offline
post #3 of 10 Old 02-15-2017, 10:23 AM
Sappuer's Avatar
Be interesting to hear if it helps. I always thought most of the spray came from the dirty water spray in the wheel well and how aerodynamics vacuum the spray in to the lower pressure area behind the bike.
Mountain state Wee-strom
Sappuer is offline
post #4 of 10 Old 02-15-2017, 11:33 AM
I used a piece of rubber sheet on my G650GS. I slapped it under the license plate to hold it in place.
Has someone whacked a piece off the bottom of the rear fender? I don't recall the top box being subjected to getting dirty.
pats likes this.
post #5 of 10 Old 02-15-2017, 11:33 AM
pats's Avatar
A must, If I could I'd have a full fender. I left small pieces of duct tape to cover the screw heads as they can pick-up and hold grit, making it impossible to get to later.
pats is offline
post #6 of 10 Old 02-15-2017, 12:43 PM
I wish Suzuki would have designed a stock one to come on the 650.
Jefferson2023 is offline
post #7 of 10 Old 02-15-2017, 05:44 PM Thread Starter
Nope fender still the same. I get spray all over the back of the box where the lock is. I searched the 2 mentioned guards and found a givi at Moto Stom in Italy for $80.00 might give that a go.
post #8 of 10 Old 02-15-2017, 09:10 PM
Vaseface's Avatar
I installed the Givi tire hugger about 6 months ago. I think it does help to keep the crud down but haven't been doing a lot of wet weather riding.
Vaseface
Northern California
14 DL1000
Vaseface is offline
post #9 of 10 Old 02-15-2017, 10:22 PM
Administrator
Coriaz Motoadventure
BMW style rear tire hugger on a DL650.....I want one, trying to figure out how to do so through this company "they are in Indonesia".
reasonable likes this.
2015 DL650 XT "Drill"
post #10 of 10 Old 02-15-2017, 10:32 PM
That piece of rubber sheet I got at OSH, maybe your local hardware store, cost only a couple bucks.
Human Verification
