LED Aux Light Recommendations - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 25Likes
post #1 of 38 Old 02-08-2017, 05:29 AM Thread Starter
SeeSully's Avatar
Hey brains trust,
I'm beginning to research adding a pair of LED Aux Lights - mainly for additional visibility with minimal night riding being factored in.
I'm looking for recommendations on best bang for buck, but not necessarily cheapest.
Also looking for advice on best wiring techniques, best position (crash bars, forks, etc.)
Cheers
Chris
SeeSully is offline
post #2 of 38 Old 02-08-2017, 07:58 AM
zener's Avatar
Here's a link to my install of LEDs that is one option for you. Relatively inexpensive, great daytime visibility, doubles light at night without being flashed down.
Light Bar and Aux. Lights - New Install
SeeSully likes this.
zener is offline
post #3 of 38 Old 02-08-2017, 09:39 AM
There's lots of info on this forum about aux lights. Use the search function.
That said, I like mine I got from richlandrick (member here).
Click here to check his option out
griff010 is offline
post #4 of 38 Old 02-08-2017, 06:38 PM
spike55_bmw's Avatar
I have cyclops adventure's Optimus Long Range and use amber wide beam covers. I attached them to the crash bars
spike55_bmw is offline
post #5 of 38 Old 02-09-2017, 02:44 AM Thread Starter
SeeSully's Avatar
Thanks for the responses.
I ended up biting the bullet on these.
Similar to the OEM ones on a BMW 1200R. Comes with the loom, relay, fuse, covers and switch for my aux shelf.
Current: 2014 DL650A
Past: ------
SeeSully is offline
post #6 of 38 Old 02-09-2017, 07:16 PM
Jimz!'s Avatar
Mondomoto's LED's shut down this past New Year. Glad to see I can still get a set from AdventureTech that are similar in design. I've had a few of those on other bikes and they are a good buy for the $
J
Jimz! is offline
post #7 of 38 Old 02-09-2017, 07:22 PM
Administrator
Cheap lights from Ebay or Amazon has served me very well.
Cryoman, Vhawg, Brojon and 1 others like this.
2015 DL650 XT "Drill"
post #8 of 38 Old 02-09-2017, 07:41 PM Thread Starter
SeeSully's Avatar
Good to hear. The kit I purchased is from ebay - Not the cheapest, but not the most expensive either. I'll report in when they're installed!
I'm pretty good with electrical wiring, but does anyone have a recommendation on the best hot (switched) location to connect the relay? Would the rear running light might be the way be a logical choice?
Past: ------
SeeSully is offline
post #9 of 38 Old 02-09-2017, 07:53 PM
Administrator
I just ran mine to the Eastern Beaver PC-8, they come on with the ignition....I didn't want a separate switch since I want them on all the time with engine running.
Cryoman, Brojon and SeeSully like this.
post #10 of 38 Old 02-09-2017, 07:58 PM Thread Starter
SeeSully's Avatar
Pardon my ignorance - Is the location of the PC-8 at the OEM aux plug behind the front faring, or the OEM heated grips plug? Or neither?
I already have Oxfords wired into the OEM grips plug, so don't want to load that up with additional current draw.
On that note, I don't feel confident that the OEM aux plug up the front will be able to cope with the draw from the lights (40W in total).
Past: ------
SeeSully is offline
Human Verification
