Sorry, I have been away for a few months. (Moving out and starting a divorce.)
Anyway, this summer I was searching for luggage options. I've decided to replace my soft bags with a SW Mototech quick-detach rack with Pelican cases. I was looking at 1450s. I don't want/need tons of room - but I do want 'enough.' There was also a thread about liners for these cases. Any advice? |
| Sponsored Links | |
Advertisement | |
#2
I lucked into a couple of bags which fit nicely into my 1550's included with some cheap roller luggage from Wally World.
You might take your dimensions shopping if Pelican doesn't offer something specific.
Stromin'Nroman NC28729, USA DL650A K7 with the usual performance-degrading enhancements "Look here brother, who you jivin' with that cosmik debris?" Frank Zappa, 1975 |
#3
a 1550 will fit *most* large pizza boxes. i have found that sometimes i have to crunch the box to clear the lock.
here's a pic...i have 1550s for the side's, too, but they were in the condo for this ride.
#4
Taco,
Get the 1550's. The scale is perfect on the wee. 1450's are a little on the small side. I bolted the 1550's directly to the new version sw-motech quick detach racks. I also purchased the optional quick release hardware and key locks, but that setup required relocating the turn signals. Decided against that option because it looks like crappy "afterthought" engineering. The brackets can still be removed very quickly with the 4 zeus fasteners. The slight downward angle of the cases allows plenty of room for passenger's feet. I bought the givi T468 liners (perfect fit) which make packing and removing your gear a snap. Last edited by xrbrett; 11-07-2009 at 11:48 AM. Reason: pics |
#5
Can you fit a gallon of milk (on it's side) in that bad-boy?
2009 DL650A Silver Strom Club Member #32 10K Club Member #208
#6
More than one.
What are you doing drinking milk anyways? You can get a case of beer in it.
#7
you sure can. maybe even 3 of them. i know i can fit 2 gallons of motor oil or antifreeze. i bet i could fit three of the coolant but i haven't actually tried.
last and only time I put a pizza in a top box, it looked more like a half eaten calzone by the time I got home much easier to balance the pizza on the tank as you ride, make sure they tape the box closed and keep the side that opens facing you, the oppisit way, the wind tends to try opening the box, works real well, box may slide and bump your forearms when leaning in corners, large pizza is easier to carry than small, cause it doesn't have as far to slide between your forearms you can fit a medium size watermellon in a 1550, when grocery shopping my rule of thumb is one layer completely covering the bottom of the shopping cart with nothing stacked will fit into 2 1550's
RandyO IBA# 9560 07 Strom 1k (54,xxx miles) 99 SV650 (135,006 miles) 82 XV920R A man with a gun is a citizen A man without a gun is a subject http://i427.photobucket.com/albums/p...dStatesMap.jpg Last edited by randyo; 11-07-2009 at 11:51 AM. |
#9
Pelican 1550s are the way to go.
You can pack quite a bit into them. Right sidecase: ![]() Left sidecase: ![]() 1450 topcase: ![]() Off of the bike, the cases can act as coolers: ![]() BUT!!!! Here is a important note; mount the cases up as high as you can on your SW-Motech racks. If you don't, you will go down during aggressive cornering. Mine are mounted as high as I could get them and I still nicked the forward, lower corner of the case on some of the turns I made. I noticed one rider, in a previous post. who has quite a bit of case "hanging down" below the racks. I would rip those off of the bike in a heartbeat; or go down. Here are mounting measurements: ![]() [Final note, I no longer use Pelican cases for side luggage. I don't use any side luggage cases at all. All of my gear packs into two dry bags strapped to my passenger seat area and I swapped out my 1450 case for one of my 1550 sidecases which acts as my topcase now. A much better setup for the riding that I do.]
2007 DL-650 (77,000 miles and in a State of Continual Metamorphosis.) "The Privilege of a lifetime is being who you are." Joseph Campbell "Be yourself; everyone else is already taken." Oscar Wilde "Be the change you want to see in the world." Mahatma Gandhi "You don't have a soul. You are a soul. You have a body." C.S. Lewis 1 Cor.13:4-7, (Love never dies.) So does the passion to ride. |
| Thread Tools | |
| Display Modes | |
