Why did Suzuki do this? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 12-07-2012, 05:33 AM Thread Starter
Hmmm....seems that Suzuki has decided to NOT produce the rear cylinder intake camshafts. The part # is 12730-17G00 and fits several years of the Wee plus several year models of the SV650. What the heck??!! Maybe I am mistaken, but I thought it was law that a manufacturer selling vehicles in the U.S. was required to provide parts for 10 years.
'92 Honda Z50R
'94 Kawasaki KLX250 modded to 340cc's
'00 Yamaha YZ426F
'94 Yamaha 125 scooter
'05 Vespa E4 scooter
'68 Vespa VBB scooter (restored)
'06 Wee
'03 Honda S2000 roadster
Boit4852 is offline
post #2 of 7 Old 12-07-2012, 07:20 AM
Moderator++
I'm not getting your meaning. 12730-17G00 is listed in the parts fiche. Did a dealer tell you they couldn't get one or what? Parts may be back ordered or temporarily out of stock but not produced is impossible. They have to be produced to build the bike. 12730-17G00 is an SV650 cam only and was never used on a stock DL650. Some Wee owners use SV cams for increased top end power.
greywolf is online now
post #3 of 7 Old 12-09-2012, 12:40 AM Thread Starter
Part # should have been 12730-27G00 which is the rear cylinder intake cam for the Wee. Most online parts dealers are showing it as a discontinued item. From Blair at SVRacing, this is the same cam from the earlier SV650's up to '02 and is referred to as Gen 1. Perhaps Suzuki is going to change the Wee's part number over to the SV which would be 12730-20F00?
'92 Honda Z50R
'00 Yamaha YZ426F
'06 Wee
Boit4852 is offline
post #4 of 7 Old 12-09-2012, 12:58 AM
Moderator++
Part numbers change when the part or the supplier changes. 12730-27G00 is listed only for the DL650 and it is discontinued. Blair may see it as a performance upgrade for the DL from the SV. Availability is weird though. The rear intake cam is not listed in any Wee fiche.
post #5 of 7 Old 12-09-2012, 08:43 AM
randyo's Avatar
I believe it's 7 years
when my 99 SV needed rebuilding in 06, the original valve guides were no longer availble oem. They were available aftermarket or the oem solution of buying a whole new updated head
RandyO
IBA# 9560
07 Strom 1k (8x,xxx miles)
99 SV650 (135,006 miles)
82 XV920R
A man with a gun is a citizen
www.gbhsurvey.com
randyo is offline
post #6 of 7 Old 12-09-2012, 09:22 AM
If the manufacturer has another component that is considered a "service replacement" for the discontinued part they often will discontinue an older part number. Why stock 2 or 3 part numbers when 1 will cover all replacements? Sometimes a service replacement part is a better part as they learned from time/experience on what was wrong with earlier designs.
While it may seem that a one part fits all approach on a camshaft wouldn't be good, as long as it passes the emissions standards and is a direct fit most owners wouldn't notice any difference.
WERKS Quiet Ride windshields for 2012+ DL 650-transform your V strom. Nothing compares.
Have questions about the Quiet Ride or clutch in your DL or SV 1000? E-mail Terry info@werksparts.com
realshelby is offline
post #7 of 7 Old 12-09-2012, 09:52 PM Thread Starter
From my emails with Blair, he states that customer/owner researched the cams and found that the Gen 1 intake cams 12710-20F00(front and 12730-20F00(rear) are the same cams as the intakes on the Wee but with different part numbers. I also went to Motosport's web site and looked at at the fiche for a 2011 Wee and the cam numbers are the same as my '06. I am very curious as to why the rear intake cam is no longer available? If the earlier model SV650 intake cams are the same, then it's not much of a problem as long as the info is readily available.
'92 Honda Z50R
'00 Yamaha YZ426F
'06 Wee
Boit4852 is offline
Human Verification
