Fuel Gauge, how many miles to first bar - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #11 of 28 Old 11-26-2012, 03:46 PM
Ranger Ron's Avatar
On my 2011 DL650 the resistance of the sender starts to change when ~1 1/2 gallons are used with the tank filled to the bottom edge of the fill ring.
The reason I know this bit of trivia is because I did lots of measurements when I was designing my "fuel gauge corrector". I needed resistance measurements at various sender positions.
Ron
Ranger Ron is offline
post #12 of 28 Old 11-26-2012, 03:49 PM
I pulled into a gas station almost immediately after seeing the gas pump blink the other day and my bike took 3.92 US gallons.
06 V-Strom DL650
John V Strom, Jr. is offline
post #13 of 28 Old 11-26-2012, 05:27 PM
ph0rk's Avatar
I was in a bad mood this weekend and took it out with my throttle hand - first bar dropped at around 80 miles (!), filled up at 82.3 and put 2.137 gallons in.
Worst mileage I've ever seen in 21k miles.
ph0rk is offline
post #14 of 28 Old 11-26-2012, 11:15 PM
ozart's Avatar
My top bar drops out right about 1.9 gallons of fuel use.
I've seen 40mpg to 65 mpg.
The resulting miles could be anywhere from 76 to 124.
The useful information is knowing how much fuel has been used, and remaining, at each indicator.
My bike ....
4th bar gone - 2.80 gal
3rd bar gone - 3.75 gal
2nd bar gone (gas pump icon blinking) - 4.30 gal
1st bar flash - 4.70 gal
ozart is offline
post #15 of 28 Old 11-27-2012, 11:39 AM
Ranger Ron's Avatar
My bike ....
I agree. Here's mine:
5th bar gone - 4 gal remaining
4th bar gone - 3 gal remaining
3rd bar gone - 2 gal remaining
2nd bar gone (gas pump icon blinking) - 1 gal remaining
1st bar flash - 0.5 gal remaining
Ron
post #16 of 28 Old 11-29-2012, 12:30 PM
Ozart and Ron,
What years are you bikes? I have an 06 and hit the little flashy pump but didn't notice it for awhile then was paying attention and the final bar and pump were flashing. I didn't want to push the bike after having it for a week.
wee willy is offline
post #17 of 28 Old 11-29-2012, 12:57 PM
Ranger Ron's Avatar
Mine's a 2011.
I've modified the fuel measurement system. I added a circuit board that measures the resistance of the sender and turns the appropriate bar(s) off as each full gallon is used. After the 5th gallon is used the bottom bar starts flashing to indicate "reserve". Since my tank holds a bit over 5.5 gallons, the "reserve" is about 1/2 gallon.
Ron
post #18 of 28 Old 11-29-2012, 02:16 PM
ozart's Avatar
Stock 2007 here.
ozart is offline
post #19 of 28 Old 11-30-2012, 08:04 PM
Kcwiro's Avatar
85-105 is a average range.. higher numbers is ofcourse likely seen on either flats with little throttle play...
I am usually seeing the first bar go at 100 unless I run fast or get in a lot of stop and go at the end of my day on the slab...
-Scott
2009 WEEStrom ABS - ~53K and still ticking - rehoned head at 35k after double stacking a o-ring on the oil filter caused engine to relive itself...
1980 GS750E (first bike)
Kcwiro is offline
post #20 of 28 Old 12-02-2012, 12:31 AM
ArmSC's Avatar
103 I'm still on my first tank though...
2011 Black Wee
2006 HD 1200c
ArmSC is offline
Human Verification
