New brake noise... What did I do wrong? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 11-19-2012, 11:33 AM Thread Starter
MacStrom's Avatar
Hey everyone...
Just did some front end work on my '11 Wee, new race-tech springs, fork gaiters and a new Heidenau K60 front tire. Cleaned everything up, got it all back together, torqued everything back to spec, and now have some front brake noise.
Before the teardown there was some metallic, high pitched squealing which appears to be gone now, but there is a low speed, intermittent, rotational noise when the front brakes are applied. It's very low toned and creates vibration right up through the bars.
What did I do???
Did I miss a step to align this thing on reassembly? Should I maybe try scuffing the pads and scotch-bright the rotor?
Thanks...
[FONT="Impact"][SIZE="3"]L1 DL650-A (Black)...[/SIZE][/FONT]
MacStrom is offline
post #2 of 5 Old 11-20-2012, 11:16 AM
MikeB's Avatar
You sure it's not a wheel bearing? A low-pitched growl under braking would suggest that as weight is transferred to the front wheel.
2008 DL650A
2016 KTM 390 Duke
- Mark Twain, 1887
MikeB is offline
post #3 of 5 Old 11-20-2012, 08:52 PM Thread Starter
MacStrom's Avatar
Thanks Mike,
Took some time today, found a video on the Galfer website. I used their method to align the front end after removing the calipers and all is well again. The service manual doesn't outline the specific order to tighten the components to bring everything back in line.
While I had everything apart I did a thorough cleaning of the caliper pistons and pins. I scuffed the pads and took some scotchbright to the rotors.
Whatever it was is fixed.
Thanks for responding.
MacStrom is offline
post #4 of 5 Old 11-21-2012, 02:20 PM
Could you post a link to that Galfer video?
I'm about to change my front pads again, and I'd love to see whatever I can before I do it.
thagg is offline
post #5 of 5 Old 11-21-2012, 05:09 PM
Stalky Tracker's Avatar
Check out Motorcycle & ATV Brake Installation Videos and see if it helps.
2017 Eastern V-Strom Gathering (website) - May 18 - 21, 2017
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
Human Verification
