Is 'A' only indicative of the bike having ABS? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 14 Old 11-16-2012, 12:46 PM Thread Starter
So DL650A is ABS equipped and DL650 is not? When I asked a CL seller if his bike had ABS, his response was "No, it's a DL650!". Yet I've seen other bikes with ABS advertised as a DL650. Is the 'A' relating to anything else the bike might be equipped with too?
I guess it's best just to ask case by case and take the thump over the head if I raise someone's ire.
socially stunted is offline
post #2 of 14 Old 11-16-2012, 01:51 PM
strompilot's Avatar
The "A" indicates that it has ABS.
'09 DL650
strompilot is offline
post #3 of 14 Old 11-16-2012, 04:17 PM
Craig's list sellers ain't always the brightest bulbs in the box and sometimes don't have a clue what they have.
Joe S.
'14 HD FLHR
'12 Concours
'11 DL650
'01 HD FXD
'09 HD XR1200
'79 BMW R100
Joe S. is offline
post #4 of 14 Old 11-16-2012, 05:20 PM
Always ask, but verify. ABS bikes have the ABS decal on the front fender, the ABS speed sensing rings on the hubs, and the ABS indicator on the speedometer face, as well as DL650A on the VIN sticker. ABS became optional on the 2007 650s.
post #5 of 14 Old 11-17-2012, 10:01 PM Thread Starter
I'll definitely rely on my own eyes to verify. Curiously, there is a 2011 DL650 (non-ABS) I was looking at that has the sensor ring on the front hub. From my automotive background I know sometimes to be cost effective the manufacturer offers one hub with a sensor ring that just isn't used in non-ABS applications. Suzuki's parts diagrams do show separate rings though.
post #6 of 14 Old 11-17-2012, 10:31 PM
BigMan73's Avatar
All 2011 DL650s are ABS (hence DL650A).
2015 Triumph Tiger 800 XCx
2011 DL-650A, Now owned by another stromtrooper
Stromputer - http://www.stromtrooper.com/dl650-2004-2011/73806-stromputer-alive.html
Stromtrooper Wiki - http://stromtrooper.wikispaces.com/
BigMan73 is offline
post #7 of 14 Old 11-18-2012, 02:28 AM Thread Starter
So even if it says only DL650 without the 'A' on the tail cover and there's no 'ABS' on the front fender it is still an ABS model? Maybe this seller really doesn't know what he has.
post #8 of 14 Old 11-18-2012, 02:41 AM
Moderator++
More typical than not.
greywolf is online now
post #9 of 14 Old 11-18-2012, 11:40 AM
MikeB's Avatar
The only place to look is on the title, not the front fender or either wheel hub. If the title calls it a DL650A it's ABS, if no A, not.
My '08 ABS has no sticker on the front fender because it's painted to match the rest of the bodywork.
2008 DL650A
2016 KTM 390 Duke
- Mark Twain, 1887
MikeB is offline
post #10 of 14 Old 11-18-2012, 11:46 AM
Moderator++
The sensor rings on the wheel hubs will be there regardless of cosmetic changes.
Human Verification
