6th gear indicator? anyone made one? - Page 3 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #21 of 36 Old 11-17-2012, 05:18 PM
Voltar's Avatar
Originally Posted by yankeepac View Post
All this talk of microprocessors has my head spinning. Seems to be a great idea, but how does one get started building a gear shift indicator type thing. I have no experience with this type of electrical projects. How does a novice learn to do this?
Yankee:
If you have experience with hobby electronics then a great deal of your battle is already won. Download manual1 and manual3 from the PICAXE.COM site and you will get a feel for how to write simple code for some simple projects. Simple projects are relatively easy to turn into other, more useful projects. The PICAXE.COM forum is a very friendly and helpful place for those times that you get stuck.
Voltar is offline
post #22 of 36 Old 11-17-2012, 06:28 PM
sbeadg's Avatar
plug and play gear indicator
I'm not savy with electrical but I found this: Gear Indicator Pro DS for DL650 V-Strom 04-11 - Electrical - Dual-Sport/ADV Parts - SoloMotoParts.com - Motorcycle Parts, Accessories and Gear
Will probably add this to the '07 Wee I think I'm going to buy Monday
sbeadg is offline
post #23 of 36 Old 11-17-2012, 06:38 PM Thread Starter
bassbronco_74's Avatar
Compare prices though... I built one for about $25...my 6th gear indicator will be slightly cheaper too... Plus it's fun to make stuff yourself
DL650K7
XL1200N (Sold)
bassbronco_74 is offline
post #24 of 36 Old 11-17-2012, 06:41 PM Thread Starter
Originally Posted by Voltar View Post
Sure. No problem. I will just add a few lines of code that make the presently connected LEG16 have a voltage on it that can power an LED whenever the bike in in 6th gear. Easy change. Also, if you elected to leave the 7 seg display completely off the new rig things would still work fine for the LEG16/6th gear thing.
Let me know if you are interested and I will fire up the candles in the lab.
That would be awesome Voltar!
I would omit the display and only have the led on it... It would be fairly simple I think... Thanks for the help!
Looking forward to another Voltar project to dink with this winter!
DL650K7
XL1200N (Sold)
post #25 of 36 Old 11-17-2012, 09:47 PM
Voltar's Avatar
$160!!!! I raising my prices!
Voltar is offline
post #26 of 36 Old 11-17-2012, 11:42 PM Thread Starter
That price tag is one of the reasons I made one via your instructions!
Home made is more rewarding too!
DL650K7
XL1200N (Sold)
post #27 of 36 Old 11-19-2012, 01:09 AM
Hi Check out EBay SBS Moto US 29.00
Cheers
Kyboy is offline
post #28 of 36 Old 11-19-2012, 06:16 AM
Voltar's Avatar
I couldn't find any $29 gear indicator....
Voltar is offline
post #29 of 36 Old 11-19-2012, 09:42 AM Thread Starter
Cheers
Are you referring to item number 290766506296 on ebay?
After much googling and ebaying i found what you were talking about...it is only $30, but you also have to wire in and install sensors on your shift lever and the motor or somewhere that a magnet can pass by it to know what gear it's in...
there are even cheaper ones i found using the same magnet technology...some were only $18...they are all from china as far as i could tell...i would be suspect of the actual quality of parts you would get...
DL650K7
XL1200N (Sold)
Last edited by bassbronco_74; 11-19-2012 at 09:45 AM. Reason: corrected my sentence
post #30 of 36 Old 11-19-2012, 10:25 AM
MikeB's Avatar
Does anyone know a way to create an "air speed" indicator by mounting an anemometer somewhere on the bike or top of the helmet, and connecting the gauge to a digital readout on the dash, perhaps by Bluetooth?
That would give a correct indication of the combination of forward movement and either headwind or tailwind, another essential piece of information.
2008 DL650A
2016 KTM 390 Duke
- Mark Twain, 1887
MikeB is offline
Human Verification
