Do Symtec heated ATV grips fit OVER the stock DL650 grips? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By semelton
post #1 of 9 Old 11-14-2012, 11:15 PM Thread Starter
That's what I thought I read in some heated grip threads...which would mean no cutting, no gluing, no mess, no muss, no dishpan hands. Or did I misinterpret?
A thousand thanks,
Todd
[B][FONT="Tahoma"]Todd Stone[/FONT][/B]
[I]aka 'Roadwryter'[/I]
The riding life: [url]www.midwestmotorcyclist.com[/url]
The writing life: [url]www.storytellerroad.com[/url]
'04 DL650
'05 GL1800 ABS
Rangers lead the way
toddwrites is offline
post #2 of 9 Old 11-14-2012, 11:19 PM
Moderator++
Some people have put them over stock grips and under grip puppies.
greywolf is online now
post #3 of 9 Old 11-14-2012, 11:26 PM
Any photos or reviews of such a thing?????
bonefisher is offline
post #4 of 9 Old 11-14-2012, 11:42 PM
Moderator++
From symantic heated grips over original grips
Before puppies installed.
After
post #5 of 9 Old 11-14-2012, 11:53 PM
Thank you greywolf.....
A walking encyclopedia.............
post #6 of 9 Old 11-15-2012, 01:26 AM
Oxford "Hot Hands" (Oxford Hothands Essential Heated Overgrips - V-Strom DL650, '04-'11 - Suzuki - Shop by Bike - TwistedThrottle.com) also mount over the existing grips and can easily be taken off when you don't need them.
Bob A.
Current bikes:
1990 Kawasaki Ninja 250 (Rebuilt)
2011 Suzuki DL650A
BobA is offline
post #7 of 9 Old 11-16-2012, 03:26 PM
BobbyLee666's Avatar
Got a suggested Symtec part number for the ones that fit over the grips? I'm a bit confused (as usual ) because when I looked them up, I found ones for ATVs where they say they are not for motorcycle use, and found motorcycle ones that fit under the grips.
[I][FONT="Comic Sans MS"]The destination is not important, only the ride there...
Current bike: 2009 VStrom 650
Previous bikes: Hondas - '65 305 Scrambler; '81 900F; '98 1100 Shadow ACE; '03 VTX 1800C; Kawasakis - '05 Concours; '08 KLR650; '01 Vulcan 1500 Classic
[/FONT][/I]
BobbyLee666 is offline
post #8 of 9 Old 11-16-2012, 03:34 PM
Moderator++
Both are designed to fit under the grips. ATVs don't have handlebar throttles so both sides heat the same. Motorcycle heaters put more heat into the clutch side grips because the bars draw heat away while the throttle tubes insulate the heaters from the bars. If the heaters are applied over the stock grips, ATV heaters are best because both sides are insulated from the bars and you want equal heat. That's also why you want controllers on the heaters if running over the stock grips or they'll get too hot.
post #9 of 9 Old 01-06-2013, 10:36 PM
symtec grips
I just installed symtec grip warmers under grip puppies. the leads route fwd from the puppies fine, no holes or slots needed. the low setting is good at 0C. the high switch is too hot. I will add a resistor to reduce power to the heaters. the symtec resistance is ~ 10.5 ohm on low and 7 ohm on high so a 5 ohm resistor may be the first try. I drilled a 13/16 hole in the flat part of the plastic tank faring with a unibit and snapped the switch in. total time 2 hrs. I think they are great.
strombastic likes this.
semelton is offline
Human Verification
