oil cooler bracket - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 10 Old 11-10-2012, 09:38 AM Thread Starter
oil cooler bracket
i hit a wild hog on monday morning and bent up the oil cooler bracket and not eaven ma susuki has one.do any of you fine people out there now of one.
thanks andy
andysway is offline
post #2 of 10 Old 11-10-2012, 02:48 PM
Stalky Tracker's Avatar
Don't even want to know how you hit a wild hog.
Looks like it is part number: 16620-27G00 for the bracket on a 04-11 Wee. Can you bend or hammer it back into shape? If Ma Suzuki doesn't have one, you may have to try on-line if no one here has one laying around.
I have used Oneida Suzuki, Ron Ayers, and MR Cycles with good luck; they or others may have one in stock.
2018 Eastern V-Strom Gathering (website) - May 17 - 20, 2018
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
post #3 of 10 Old 11-10-2012, 10:50 PM
I have read about "oil-cooler relocation" kits.... perhaps this would be an option for you.
Personally, if the bracket is only bent and the oil-cooler is still functional, I would consider simply leaving it. (proud battle-scar
BruceP is offline
post #4 of 10 Old 11-11-2012, 10:21 AM
MikeB's Avatar
Just the bracket? Bend it back. But how in hell can you get a hog between the forks and the oil cooler? It must have been a tiny piglet if you ran over it and did not dump.
You sure it wasn't an armadillo?
2008 DL650A
2016 KTM 390 Duke
- Mark Twain, 1887
MikeB is offline
post #5 of 10 Old 11-11-2012, 12:03 PM
strompilot's Avatar
Wild hog? Wow! They made a movie about that a few years ago. Near the end, they all got hit a bunch. Glad you survived.
'09 DL650
strompilot is offline
post #6 of 10 Old 11-11-2012, 08:36 PM
Whoa! You say you hit a Harley Davidson?
carolinagator is offline
post #7 of 10 Old 11-11-2012, 09:37 PM
Might try Bike Bandit, I've had good luck with them for oem parts.
rbomb is offline
post #8 of 10 Old 11-12-2012, 01:13 AM
Hog
Any pork chops in the fereezer? On a more serious side, that relocation kit from Touratech looks like something I would like to try. It moves the cooler out from behind the exhaust pipe.
bsbiker is offline
post #9 of 10 Old 11-12-2012, 07:05 AM Thread Starter
thanks for the help guys,i did try all the places you said and no one has that part,and it hit the front tire and then the oil cooler and yes i knock the crap out of it for there was poop all over the bike.and it was a hog i have the hair stuck inbeetween the tire and rim.
thanks andy
ps can not aford that kit i got the whole bike for 311.00 dollars
andysway is offline
post #10 of 10 Old 11-15-2012, 03:56 AM Thread Starter
found it at mr cycles
andysway is offline
Human Verification
