Lowering Links - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 13 Old 04-21-2017, 04:55 AM Thread Starter
CodeeT's Avatar
Lowering Links
So I just bought a 2006 vstrom 650 that has been lowered and I desperately need it back to stock height. Does this require a stock set of links or can I just remove the lowering links? I am not very mechanically inclined and this is my first bike. Thank you in advance for the advice and help.
-Codee
CodeeT is offline
post #2 of 13 Old 04-21-2017, 08:00 AM
Stromtrooper.com Sponsor
richlandrick's Avatar
You have to replace the links. Go here for a description of the process. It's pretty simple.
DL650 and Gen 1 DL1000 Raising/Lowering Link Instructions - AdventureTech, LLC.
I suggest listing the links for trade for a stock set here on Stromtrooper. I expect someone out there will be happy to swap you even.
richlandrick is offline
post #3 of 13 Old 04-21-2017, 08:09 AM
Motor7's Avatar
The links are the two arms below the rear shock(see part #13 in the diagram):
2006 Suzuki V-Strom (DL650) REAR CUSHION LEVER | Babbitts Suzuki Partshouse
Stock links are 140mm center to center. Longer links aka dogbones lower the bike. Yes, you will need to replace them with either oem length or you can go shorter to even raise the rear of the bike further. Rick sells both shorter and longer:
Gen 1 and 2 DL650 and Gen 1 DL1000 - AdventureTech, LLC.
I'm 6'4 w/36" inseam and raised the rear by 3/4" with 133mm bones. I can still flat foot so I could have gone higher, but then I would need to mod the centerstand. As it is now, with new tires on I can barely turn them when up on the stand.
I have a pair of oem bones you can have if I can find them.
'15 DL650XT
Motor7 is online now
post #4 of 13 Old 04-23-2017, 12:19 AM
alexanderbeetroot's Avatar
I just put a set of Rick's Adventuretech lowering links on my 06. I have the stock set if you need some. Send me a email.
2006 DL650
alexanderbeetroot is offline
post #5 of 13 Old 04-23-2017, 12:20 AM
Make that a Pmail. Auto-correct strikes again!
2006 DL650
post #6 of 13 Old 04-23-2017, 12:41 AM
Macdoc's Avatar
It's not just the links tho ...the suspension may have been altered as well and that needs to go back to stock.
Australia> 04 KLR650 93 ST1100 sold Canada > 10 Wee ABS 2009 CBF1000 09 Burgman Exec sold 10 NT700v sold
Travel photos> https://500px.com/macdoc/galleries
Macdoc is offline
post #7 of 13 Old 04-23-2017, 11:29 AM
There are a number of threads on the forum about raising and lowering the bike. You can also raise the front forks to match, using longer spacers in the fork tubes. Probably not needed with less than an inch over stock in the back. Some riders lower the front and leave the rear stock for quicker cornering response. If you raise the rear, it's about the same thing. You can also get a taller seat. or a seat pad with beads or sheepskin. It all raises the seating position. Have fun with it. Bobby
bobbyvstrom is offline
post #8 of 13 Old 04-25-2017, 03:19 PM Thread Starter
CodeeT's Avatar
Guys, thank you both for offering me the stock height ones, but I think I want to go with at least 3/4" raise. I'm 6'3" 210 pounds and my wife loves to ride with me which is always bringing the bike down even further. So my bike has been lowered by 1 and 1/8", centerstand is dragging going over speed bumps when riding 2 up. I was thinking raising 3/4" and then getting a stronger rear shock hoping that would make it less responsive(for lack of a better word) when I do have lots of weight on the rear i.e. a passenger or luggage. What do you guys think?
CodeeT is offline
post #9 of 13 Old 04-25-2017, 05:04 PM
A lot of guys have done exactly that. Most of the after market shocks have stiffer rear springs. Unfortunately there are not o lot of choices on rear spring weight. You might check with Rich and Sonic springs. I think I remember that they were carrying shock springs now, but I'm not 100% sure.
People used to put the wilber's shock spring on the stock shock. I did that and was very pleased with the result.
The progressive suspension shock is also highly regarded. All our customers that have gone this way have been delighted.
Aftermarket Rear Shocks - AdventureTech, LLC.
post #10 of 13 Old 04-25-2017, 05:13 PM
Codee, check a local motorcycle suspension shop about changing the spring on the shock and the forks. You need springs suited to your loaded riding weight.
There are good upgrades to the damping in both the forks and the shocks, but suitable springs is always the first step.
[I]"Older people who are reasonable, good-tempered, and gracious will bear aging well. Those who are mean-spirited and irritable will be unhappy at every period of their lives.
"Let each of use properly whatever strengths he has and strive to use them well. If he does this, he will never find himself lacking."[/I]
Human Verification
