cheap oil filter protection - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 34 Old 02-06-2008, 05:16 PM Thread Starter
I don't ride off-road and I still don't like the oil filter sitting out in the open like it does so I made this filter protector from a 2" fernco coupling and a 2" ABS pipe cap. Just split the coupling down the seem and open the clamps to allow it to slip in about 1/2" and tighten clamp. Slip the other open end over filter till it hits the block and tighten the other clamp. Done. Twenty minutes tops. I haven't riden with it yet but can't see any problems as the plastic cap doesn't touch the filter. Has just a bit of flex at the cap end to allow for movement. Should stop anything I will hit that wouldn't destroy more than the filter anyway. I'm trying pic for the first time so? Don't know how to make them small enough for this forum, help!!
http://i249.photobucket.com/albums/g...g/IMG_0371.jpg
http://i249.photobucket.com/albums/g...g/IMG_0370.jpg
http://i249.photobucket.com/albums/g...g/IMG_0376.jpg
http://i249.photobucket.com/albums/g...IMG_0372_1.jpg
http://i249.photobucket.com/albums/g...IMG_0364_1.jpg
msy88 is offline
post #2 of 34 Old 02-06-2008, 05:47 PM
ElBando's Avatar
Go to photobucket and post your pic there, then copy the link to your post here. I want to see the pic.
2007 DL650 ABS ( she thinks it's hers, but it's MINE )
2006 GL1800 ABS ( ours )
2001 VLX600 ( spare )
2000 4X4 Rancher ( his )
2000 4X4 Rancher ( hers )
1991 XL250R ( hers )
1983 XR250L ( his )
1974 CB360 ( retired )
All from the same people who
brought to you "PEARL HARBOR"
Patriot Guard Rider
AMA Member
U.S. Navy Veteran
ElBando is offline
post #3 of 34 Old 02-06-2008, 10:46 PM Thread Starter
Thumbs up thanks for pic info
I was able to add the pics to the original post. Thanks, I'm still new at this but it worked perfectly.
msy88 is offline
post #4 of 34 Old 02-06-2008, 11:02 PM
won't the engine heat up enough to melt the coupling?
QuinnJoBlow is offline
post #5 of 34 Old 02-06-2008, 11:09 PM
Send a message via MSN to simply40
wish I would have thought of that
nice job, may have too use this until my economic incentive comes this summer and i can afford a heaveir duty one thanks for the post.
simply40 is offline
post #6 of 34 Old 02-06-2008, 11:11 PM
didnt think of that, let us know
simply40 is offline
post #7 of 34 Old 02-06-2008, 11:14 PM Thread Starter
It just touches the block at the base of the filter and shouldn't get that hot since it has a 3/4 split.
If it does, it can pulled out 1/4" so that it doesn't touch the motor. Will have to see.
msy88 is offline
post #8 of 34 Old 02-06-2008, 11:18 PM Thread Starter
Talking Lowes
Does anybody think Lowes knows they sell motorcycle accessories and parts?
Storage tubes and now filter protectors. Who knows whats next and what else is already out there.
msy88 is offline
post #9 of 34 Old 02-07-2008, 03:41 AM
Neat penny tech idea.
05 / 650 in blue
88 / KDX 200 in green
81/82 DT 175 Yamahussies
78/ GT 750 water pumper
75/Suzuki 125 RV
water warrior is offline
post #10 of 34 Old 02-07-2008, 06:57 AM
Kimchirider's Avatar
I splurged for a full skidplate since I managed to dent my pipes twice on the road (brick flipped up once, big hunk of broken pavement once), but getting some protection on the filter is a good start. Can't imagine doing gravel roads with it hanging out there like that. To hijack your thread, I noticed some oil on your front cylinder. Any idea where that's coming from?
Kimchirider is offline
Human Verification
