Hi all.... I have a TEKA2 Factory Pro and I would like to use it on a DL650 L2, but my TEKA 8 pin conector it does not match with 6 pin conector on L2, is there any adaptor or so for it ?
![]() Another question , I need to check TPS on a bike like that, where is that conector in the bike ? Thanks |
| Sponsored Links | ||
Advertisement | ||
#2
The dealer mode connector for checking the TPS is at the rear under the cover on the left side below the seat. I wouldn't try changing the fuel map. It is very good stock.
#3
Teka, SFI Tuning procedures, Suzuki, Factory Pro
I was just looking around. DTC on the L2 is a white 6 pin connector. On the SV it has a black SDS connector. I agree with GW, the stock map is pretty good.
2005 Suzuki SV1000R ![]() 1985 Yamaha XT608N ![]() 2012 Suzuki DL650AL2, over 15,000 miles already! |
#4
ok, I found it.
I did the clip bussines , but on the screen I canīt find -C00 and I change the fields with my left index and just ...... Odo, trip , and 0000. ......am I skipping something ? ![]()
#5
Are you certain you are connecting the White/Red & Black/White wires with the jumper?
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
