Changing Chains - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
DL650 - 2012+ DL 650 2012 +
Old 12-10-2012, 07:47 PM
Question Changing Chains
I know the wisdom is that you should change chains and sprockets at the same time as a worn out chain will wear out new sprockets quickly and vice-versa. I'm thinking of putting a 16T front sprocket onto my bike which has 5000 miles on the original chain / sprocket and which has been Scottoilered since new, so is it prudent, or just a waste of money, to fit a new chain / rear sprocket at the same time?
Old 12-10-2012, 08:12 PM
With that low of mileage and a Scottoiler no need to replace anything but the front sprocket.
nvr2old's Avatar
Shouldn't be a problem. I did the same 16 tooth change over at around 5000 and went almost 14,000 more before a new chain went on. Sprockets still looked near new even then.
DL-650 K5 red
93 DR 350S
for the safety of existance
Old 12-10-2012, 09:05 PM
I changed the chain and not the sprockets, of they are not worn, why replace them?
Old 12-10-2012, 10:51 PM
I agree with notacop
Old 12-10-2012, 10:55 PM
The "get on with it and stop worrrying" team seem to be winning at the moment!
Old 12-11-2012, 02:42 AM
Front sprocket, not a worry.
If you change the fronts when they start to show wear you'll usually get more chain life anyway. They wear 3x faster than the rear. With an oiler the chain stretching to match the sprockets if the main life eater.
Pete
Old 12-11-2012, 04:53 AM
Don_T's Avatar
Wink Get on with it and stop worrrying...
I have just replaced the 15T with a 16T after 16.500km - without replacing chain and rear sprocket.
I also use a Scottoiler and the chain and sprockets still looks like new.
Suzuki V-Strom DL650AL2 and Yamaha WR250R - www.bike-addict.dk - It's not what you ride but how you ride it
Old 12-11-2012, 10:03 AM
D.T.'s Avatar
I have found that the OEM sprockets are pretty damn good on the suzukis too. The L2 has a Sunstar rear.
If you went to aluminum Renthals for twice the price I bet they would last half as long.
2005 Suzuki SV1000R
1985 Yamaha XT608N
2012 Suzuki DL650AL2, over 13,000 miles already!
Old 12-11-2012, 08:11 PM
Great information, thanks
