Rattling boxes on adventure - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
DL650 - 2012+ DL 650 2012 +
Old 12-09-2012, 11:54 PM
Default Rattling boxes on adventure
I bought my adventure last weekend. One of the boxes was loose when it was at the dealership - the shop tightened it before I left. Now both boxes are just a little loose. I tried tightening the nuts on the inside of the rack, but the washer (?) between the rack and the box just spins. I don't have an owner's manual yet (they lost it - they're mailing me one), how do I tighten up the boxes to the rack?
thanks
Old 12-10-2012, 08:30 AM
Seems to me you need some Loctite or other thread lock on the bits and pieces if they're coming undone so quickly. I have the Touratech Zega panniers so can't give any advice on what needs tightening up on your panniers, sorry.
Old 12-10-2012, 10:14 AM
TwoShots's Avatar
If you're referring to where the boxes slide on to the racks...
I had occasional rattles as well. Didn't seem to me any bolts needed tightening. So, I wrapped a small piece of electrical tape inside and around the groove on each of those round things.
They don't rattle anymore.
1942 Brick Bungalow
1968 Dream Wife
2007 Retirement Certificate
Old 12-10-2012, 08:52 PM
Small rubber o-rings from an auto shop will stop the rattling too and give you that snug feeling.
Alexi
Old 12-10-2012, 09:34 PM
Thanks all!
Old 12-10-2012, 10:11 PM
That's what the tapes is for that should have come in the saddlebags. Seems Suzuki knew they were prone to rattling.
Old 12-12-2012, 01:49 AM
I don't exactly what my dealer did but the service writer said it was a minor adjustment and the bags were tight without the use of tape or O rings.
Old 12-12-2012, 09:08 AM
It's the lock latches on the rack on mine that rattled. I unlocked and removed the bag then loosened the bolts that hold the latch to the rack slid them slightly forward and tried again. It may take a couple attempts but the noise should go away.
2012 DL650 ABS Adventure
2008 WR250R
2000 KLR650
Old 12-12-2012, 07:08 PM
Make sure you secure the locks. Those small c clips don't always hold. Some extra glue should be used. There are threads on here about people losing their locks due to vibrations.
Alexi
