| DL650 - 2012+ DL 650 2012 + |
#11
Rooster today Feather duster tomorrow |
| Sponsored Links | ||
Advertisement | ||
#12
From what I see in your video, it looks like the oil level is full when the engine is running. There should be none or very little visible in the sight glass with the engine running. The oil level should be checked with the engine off, on level groung with the bike balanced upright.
I also had the clicking sound after my first oil change, after riding about 100km and sitting in the garage for two days it went away. |
#13
The 1950 F-1 Ford is my fathers. He now has it painted and wood bed installed. The only trouble is old age has catch-up with my dad so he can't enjoy all the hard work of his restoration. |
#14
I re-checked the oil level and yes, I over filled it a little. I drained it to the proper level. Rookie mistake by changing my oil in a semi-level location in lieu of a perfectly flat location and by topping off the oil.
#16
Had same issue after firs service at 1000km, now I have over 2200km and the noise disappear.
Life isn't about finding yourself, it's about creating yourself. |
#17
Kevin L2 DL650A The Orange Machine K7 DL650 Hi Yo Silver R.I.P! |
#18
08 DL1000 with stock pipes, one of the noisiest bikes I ever owned while being so quiet, but none of it means anything, ignore it and ride. Been said 100 times on this forum. Now my 78 Sportster, with drag pipes, never heard any mechanical noises.
ive had this clicking noise from new ...was told at the dealer "they all do that " so my next service going to go to a different suzuki dealer to see if its "ok" before the warranty runs out ....it seems to be coming from the front of the engine as i pull away from standstill ..sounds just like a loose tappet & goes after 2th rpm ..it also sounds a lot quieter as the engine gets hotter ...been told its just "end float" on the cam .....
#20
So how is now, same noise still?
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
