Battery meter - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
DL650 - 2012+ DL 650 2012 +
Old 11-20-2012, 04:17 PM
Default Battery meter
Can someone recommend a decent battery meter for not a lot of money. Perhaps one that i could mount on my handlebar to keep track of battery voltage, esp. now that I am using electric gloves and jacket. Thanks. Phil
Old 11-20-2012, 04:48 PM
LoneStrom's Avatar
Here ya go,$8 with shipping on Ebay.
I put it a $3 radio shack project box for mounting.
ImageUploadedByMotorcycle1353448049.222267.jpgImageUploadedByMotorcycle1353448081.943050.jpg
1982 GS850..BLACK SUNSHINE,the tripod
2007 DL996AR..BRUTUS
Ah screw it,I'm goin ridin !!!!!!!!
Old 11-20-2012, 07:09 PM
Does that meter wire directly to the battery and can it be mounted where it can be easily seen? Thanks for your quick reply btw. Phil
Old 11-20-2012, 08:32 PM
Voltar's Avatar
I use the same VM pictured above. I just double stickie taped it under my Pat Walsh shelf and it is happy there. The claim is that the meter is water proof and I have gotten mine wet once or twice. For the price, if it broke I would replace it with exactly the same type unit.
I like it.
Old 11-21-2012, 07:10 AM
On other bikes I've always wired the voltmeter into an ignition switched supply so it doesn't attempt to flatten the battery. Might give slightly erroneous readings, but when the meter costs a few pence it isn't likely to be 100% accurate.
Old 11-21-2012, 11:40 AM
LoneStrom's Avatar
I will mount them ( I bought 3 ) all in different places on each bike.I to have a PW dash on the V and it will mounted there.
Old 11-21-2012, 03:16 PM
Toytech's Avatar
I chose a Koso brand digital gauge. Small compact and attached with double sided tape. I did not need to drill any holes, just slid them through one of the fairing screw holes drain slot. HOWEVER, it was not water resistant until I placed a dab of clear silicone sealant at the exit for the wires.
I don't mind the going and I don't mind the stopping. I absolutely hate the stop and going.
