I'm confused on the windshield up and down adjustment. Am I suppose to push the rubber nut out the back and then into one of the other holes? It just doesn't look like it will work with the upper and lower holes being raised the way they are. Help!
Chuck 2012 650 Adv |
| Sponsored Links | ||
Advertisement | ||
#2
The item in the center hole is called a 'well nut' (it has other names, too).
You need to grab it with fingertips and gently twist/pull it out of there. Then place it into a different hole (sometimes easier if you thread a bolt into it and push on the bolt). Repeat at other locations, reattach wind screen, ride, smile, then realize that it didn't make much difference where the windscreen was located (IMHO). Have a nice day.
L2V -- she's a stocker! |
#3
The windscreen has tubular extensions that will fit between the raised sections. Just swap the well nuts with the plugs to get the configuration you want. Unlike the older models, the well nuts come out from the front.
#4
Got it. Thanks
Any major difference performance wise between the two windshields that come with it? Sent from my iPhone using Motorcycle.com Free App
Chuck 2012 650 Adv Last edited by cbeam2; 11-06-2012 at 09:00 PM. |
#5
BTW if you push too hard the well nut usually drops down onto the floor, but sometimes lodges in the area below it. If you need spare ones the ones in a Suzuki labelled bag are way more expensive than the same item that isn't in their bag. |
#6
I haven't tried the windshield with wing on top. Does it not help at all?
I'm not having any problems to speak of except when I sit tall I get lots if wind noise on my helmet. Sent from my iPhone using Motorcycle.com Free App
#7
I have not tried the non-vario windshield, but I did try adjusting the flap on my vario. The difference between highest and lowest position is ever so slight, and maybe just more of a placebo, but I do think that it looks awesome with it fully extended, and well, thats good enough for me.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
