behind cover - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
DL650 - 2012+ DL 650 2012 +
Old 11-05-2012, 01:09 AM
Default behind cover
I am looking to run a line down the right side of bike. can i do this if I just remove the large cover on right side or do I have to remove more.
Respectfully, Doug
Old 11-05-2012, 07:54 AM
I assume you are talking about a wire. If so, I had no trouble running two wires from the battery to the front of the bike, by just removing the side panel on the tank. Easy
Old 11-05-2012, 08:00 AM
nbsdave's Avatar
did the same thing, no prob
just zip tie the wire in a few places to be sure it won't chafe anywhere
Old 11-05-2012, 10:03 AM
Thank You for your replies I will do that .
Respectfully, Doug
Old 11-05-2012, 02:27 PM
I ran several wire bundles on my bike inside the left frame (clutch side for clarity), following the factory wire bundles. I used a flexible pick-up tool to fish through the parts you can't see (frame and gas tank), and grabbed a string, I pulled the string through then taped the string to the end of the wire and pulled that through. I fit several shielded wire harnesses like this.
Look inside the left front fairing behind and below the lights and you'll see a big wire harness there - just follow that.
Old 11-05-2012, 02:47 PM
jpCoder's Avatar
Default Also done
Also ran a couple of wires front to battery area following the existing bundle. I twisted the 2 wires together, neater and will not hang up when pulling thru tight spots.
2002 V Star 650 - Traded
2012 V Strom Glee - Current
Old 11-06-2012, 12:34 AM
Thank you all you gave me the ability to complete the mission. Again Thank You all.
Respectfully, Doug
