| DL650 - 2012+ DL 650 2012 + |
I have the Richland Rick's footpeg lowering kit and Dan Vessel's elite DL650 highway pegs. If I purchase a 2012 DL 650 can I transfer these parts ??
"If you have to tell it to the judge, you've had too much fun." |
| Sponsored Links | ||
Advertisement | ||
#2
Richland Ricks footpeg lowering kit from my '03 Vee went right on the 2012 Wee. The brake light switch connection might need a bit of adjusting but should be easy. I think the kit is the same for all V Stroms as far as the main part goes, the stuff to connect to the brake light switch is different on the Vee.
Don't know about the highway pegs.
'12 DL 650- '04 DL 650- '03 DL 1000- '04 R 1150 RT WERKS modified clutch baskets for DL and SV 1000's. The BEST in chudder control, noise control, and lasting durability! AVAILABLE HERE: www.werksparts.com Want straightforward easy to understand answers to clutch basket questions or concerns? E-mail Terry info@werksparts.com |
#3
If you have the ones that mount over top the givi crash bars it should work seeing as the bars mount the same for all years.
'07 Yamaha Vstar 650 (sold) '09 Honda CBR600RR (sold) '12 WEEEEEEEstrom
#4
Thanks, guys. Appreciate the quick response. I have the cruiser pegs that work without crashbars and mount back to the frame under the tank, with a bar across in front of the engine. I think these cruiser pegs might be a problem to transfer.
#5
The primary frame is the same. Shouldn't be a problem unless there's an interference with the plastic.
L2V -- she's a stocker! |
#6
If you have this, I'm not seeing anything on the 2012 that will interfere as long as you don't have crash bars. Crash bars use the same mounts so it wouldn't work with them.
#7
Thanks Henery the 8th and Greywolf.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
