#11
2 inches is dangerous. 1-1/8" to 1-1/4" is the maximum. Your tire can hit the inner fender. With the rear lowered more than the front, the aerodynamics are worse than stock so front end lift at speed is even more of a factor. You may have been lucky so far but you're pushing the envelope.
As to the 3/4" front lowering on my bike, it's really 3/4" fork extension so isn't quite an actual 3/4".
| Sponsored Links | ||
Advertisement | ||
#12
fuelly link: http://www.fuelly.com/driver/jbw/dl1000 |
#13
I lowered mine just like Greywolf had done and haven't seen any issues. 3/4" Koubalinks in the back and moved the front tubes up 3/4". I am able to get more of my feet on the ground any more lowered and I think I would need a new side stand though. I haven't hit the skid plate or foot pegs on anything yet between road and an easy ATV/OHM trail but I don't drive very aggressive either.
If you do lower it and are using a side stand just be prepared for it to feel a little funny putting the stand down especially loaded with luggage. I haven't had any real issues with it but the bike sits more upright on the stand. |
#15
I'm a short inseam person (about 30" I think), and with the L2 as it was, I couldn't get confidence with a secure foot hold on uneven ground or camber.
I put the KoubaLink 2 links on the back for an 1 1/8" height decrease -- and then pushed the fork tubes up the tripleclamp 5/8". I now get the full ball of both feet on the ground for secure footing around I suppose this setup sounds like it'd be a slow turner -- perhaps it is and I wouldn't know, not having anything to compare it with. However, it feels great to me. (I could try the local shop's demo bike to see if there is a difference). My setup is great on the open road and on gravel roads. The traffic here is minimal -- so can't usefully comment there. |
#16
Chris,
How do you find the side stand after lowering that much? |
#17
[I see picture didn't attach -- maybe it was a size thing (2.265 KB) -- I'll try again if it would help to see it] Last edited by chrisbre; 11-07-2012 at 02:09 AM. Reason: picture didn't attach |
#18
bike on sidestand.jpgHopefully this worked -- a picture of the bike on a flat surface
#19
That looks fine -- doesn't look that different to the regular bike to me!
#20
And the handling certainly doesn't feel compromised. I think I could have lived with a pre 2012 wee as it is -- but this new and much better model was a must have in comparison -- so a solution for the additional height was needed (for me), and I decided to go all the way to really comfortable. If the bars were raised with a set of risers -- then the forks could come up the tripleclamps more -- but I stopped at 5/8". I might look at risers anyway, to see if the BarkBusters I've bought will then clear the dash when the bars are on full-lock. |
| Sponsored Links | |
Advertisement | |
| Tags |
| handling, lower, lowering, suspension |
| Thread Tools | |
| Display Modes | |
