Wobble getting worse - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
DL650 - 2012+ DL 650 2012 +
Old 09-02-2012, 01:56 PM
Default Wobble getting worse
I love my bike. I just passed 2000 miles. I noticed and learned about the decel wobble. I figured it's not a big deal. But now, its getting really bad. On the decel it wobbles several inches. It started to wobble when I accelerate too. even with both hands on the bars. Any thoughts? I took it to a mechanic and he checked it out. He said the front end looks good. I'll take it to the dealer when the weather gets cold. There wait time is about a month
Old 09-02-2012, 02:51 PM
JRWalker's Avatar
Originally Posted by skysail View Post
Any thoughts?
running low air pressure can screw up a tire in just a few miles.
fuelly link: http://www.fuelly.com/driver/jbw/dl1000
Old 09-02-2012, 03:03 PM
Black Lab's Avatar
What Kinda Bike Is That?
I have written about this topic; passionately. It is a new bike, with not many miles on it. When these kinds of reports come in, I STRONGLY feel that, the stem bearings have been set up too loosely.
I also STRONGLY feel that, when the stock stem bearings are in place, and the Service Manual torque settings are used to check the bearings, that this in incorrect. Again, too loose. This is why so many mechanics and dealers report to the owner, "The front end is fine." Yet, it isn't. The "wobble" is still there.
I can't help you with a proper torque setting for OEM stem bearings. I can direct you to a way to eliminate the "decel wobble"; whether you are riding on new tires, worn tires, or any brand of tire.
Steering Stem Bearing Replacement / Upgrade « Black Lab Adventures
For adjusting your own stem bearings, this article may give you some insight and inspiration as to how to tackle tightening down OEM bearings.
How I Adjust The Steering Stem Bearings « Black Lab Adventures
B.L.
2007 DL-650 (111,000 + miles)
"In most men, there lurks a lesser man, and his presence smells in the the sun."
1961, Ernest K. Gann: "Fate Is The Hunter"
Old 09-02-2012, 03:25 PM
I agree with Black Lab. I would have a hard look at the steering stem bearings. A front end wobble is NOT normal, and you haven't lived until you find yourself in a nice tank slapper ay 60 mph or so.
Old 09-02-2012, 09:49 PM
I did a 600 mile weekend, now at 1900 miles, and noticed a wobble while coming home this afternoon on the interstate. Hand a little hand fatigue and let go for just a second, front end started to wobble. I had recently installed a fork brace and thought I might have screwed something up but I hadn't noticed the issue until today.
Dang It!
04 DL1000, PCIII, Cee Bailey Shield, Center Stand, Bestem Top Box SOLD.
2012 DL650, Cortech Tank Bag and Tail Bag, Richland fork Brace, 16T front sproket, GPS mount, go-cruise, cramp buster.
Old 09-03-2012, 04:17 AM
citizen4's Avatar
Originally Posted by deuce View Post
.....and you haven't lived until you find yourself in a nice tank slapper ay 60 mph or so.
lol
2012 DL650A
"Riding a motorcycle is very good for your health until it suddenly isn't. It's like having a poison pill in your bottle of Tylenol. You'll run into it one day, and the relief the others gave you probably wasn't worth it at all." K'ale
Old 09-03-2012, 11:14 AM
Moderator++
Try over 100mph. I can show you the scars.
Old 09-03-2012, 11:49 AM
V-Tom's Avatar
While waiting to tighten the steering stem bearings you might also consider that higher load on the rear of the bike, lower air pressures, and wear on the tires can make it worse.
..Tom
Road Toads Charter Member - 2006 V-Strom DL650: 202,000 km 125,500 miles, 2012 DL650 New March 2012 50,000 km
Why Cars don't see bikes (SMIDSY)
SMIDSY detailed report
Old 09-03-2012, 09:12 PM
I had a minor front end wobble, most noticeable on decel and when I took my hands off the bars. I played around with tire pressure and that helped, then I added a bit of preload to the rear and that took it away completely. Try playing around a bit with your settings.
Currently running 35psi front and 38psi rear...I go about 210# and often carry gear in the top case.
Old 09-04-2012, 09:22 AM
I didn't think about that, this was the first "trip" I have taken and had quite a bit of gear in my tank bag and my rear bag. Probably not more than 20 to 25 lbs total but all, pretty much, at the extreme rear of the bike.
Air pressure was fine, more pre-load to come...
