Trouble mounting SW-Motec EVO SideCarriers - Page 3 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
DL650 - 2012+ DL 650 2012 +
  #21
Old 03-16-2012, 12:33 AM
Default Newbie just joined
I have been trying to register for about 2 weeks so I can post, finally tried Google Chrome and it let me complete the registration process.
I also had a challenge with installing the right hand SW Motech bracket, I just used a bit a of force on the front connector to make it line up.
I also did not like the kit supplied to lenghten the wires on the turn signals, so I cut them and added a piece of wire and soldered them. I used heat shrink to make it nice and tidy.
I noticed that I could make a little channel in the back of the bracket with a dremel tool and reroute the wire under the bracket and back into the existing hole, made for a much tidier install, this may work without extending the wires but I'd already completed the splice.
I also installed the center Stand, attached 1 spring at a time and was easier than expected, the SW motech bash plate was more of a challenge as the bottom rear holes did not line up without using a lever to move it into place.
Just got to conenct up my Oxford heated grips and I'm almost done.
Cheers.
Old 03-16-2012, 12:53 AM
ccriderstaff's Avatar
Originally Posted by rms View Post
ADVENTURE MOTORCYCLE PARTS
Sells the quick-lock racks for $10 less than Twisted Throttle and only charges a flat $20 shipping rate any where in the lower 48.
Thank you RMS for the lead! Appreciate it!
Jon
CentralCoastRider.com
ChristianADVRider.com
Old 03-21-2012, 11:13 AM
twistedthrottle's Avatar
Twisted Gear Specialist
Hi guys.
I was directed to this thread two days ago and fortunately, yesterday we did an install of side carriers on a 2012 DL650 for a local guy. Armed with your descriptions we were able to identify a small fix to address the slight misalignment. We have already informed SW-MOTECH of what needs to be adjusted in the kit and are working on a solution (free) to send to those who already purchased the side racks. It will take a few days to organize the solution. More to follow.
Kev
TwistedThrottle.com Toll-free 855-255-5550
Follow us on YouTube, Facebook and Twitter!
Old 03-21-2012, 07:37 PM
Jarhead88's Avatar
Originally Posted by twistedthrottle View Post
Hi guys.
Kev
Kev,
Thanks man. I am glad Im not crazy! All it requires is a small spacer to make it perfect. Will you guys automatically send out the new part? Also, it looks like the right box sits a little higher than the left due to the space constraints. Hopefully this small adjustment will fix that as well. I know I am anal, but the devil is in the details.....
Old 03-21-2012, 07:54 PM
Very handsome boxes. Just how wide are they outside to outside?
Just think of all the travel destination stickers you could get on those things!
Old 03-21-2012, 08:07 PM
Jarhead88's Avatar
Thanks! You know I am out of town right now and dont have access to the bike. They are really wide though! I think some folks have posted somewhere around 40 inches (approx 101/102cm give or take). I can measure when I get home. They will definitely come off in the winter time when I have to store 2 bikes and a van in the garage. They are quick release though so no problem....
Old 04-17-2012, 01:02 PM
Hello, Has anyone heard back from Twisted Throttle regarding the adapter fix for the SW Motech Side Racks or has anyone received one?
Jon
Old 04-17-2012, 06:21 PM
91TCCRA#1's Avatar
I haven't heard anything yet.
Steve.
12 Wee
06 FJR
Old 04-30-2012, 12:32 AM
Default Boxes are different Heights
Hi guys.
Kev
I hope SW Motech can re-engineer the right hand mounting bracket for the DL650 2012, mine is a almost an inch higher than the left and the box sits on an angle. I had originally made it fit by leaving the brackets loose and then using a bit of forced to get them to lock in place, and tightened everything up once in place.
I put the bike on the centre stand on a level floor, removed both Trax side boxes and measured from the floor to the center of the front top connector, left side 31 1/4" Right side 32 1/8" I would say that is unacceptable and I think SW Motech should replace the right hand rack.
The boxes look very unbalanced and it really is disappointing to have chosen a good quality company and get poor workmanship, even carpenters framing a house are more accurate than that.
I bought them from my Suzuki dealer who ordered from Twisted Throttle.
Any one else have these same issue?
Old 04-30-2012, 01:16 AM
HotPockets's Avatar
Cheers.
i had the same issue with mine. i tried using a center punch to get mine to line up and i couldnt get it to work. i actually had to bend (beat into submission really) the front left bracket that mounts to the primary cover so i could get everything to line up...
