#211
Stock - 88db. Akrapovic - 94db. You can see more data here. I would not install the exhaust without using a torque wrench. I was in no hurry and very thorough (leaving no static tension in the pipes, using recommended thread grease and proper torquing) and the install took me about an hour. As this was the second time I installed an Akrapovic on my Strom, I had some some experience with the task. NB. Be very carefull not to scratch the swingarm when removing the stock exhaust (it's the clamp on the rear header pipe that can cause scratches) - I would suggest protecting the swingarm with rags before you start to remove the exhaust.
Suzuki V-Strom DL650AL2 and Yamaha WR250R - www.bike-addict.dk - It's not what you ride but how you ride it
| Sponsored Links | ||
Advertisement | ||
#212
Well I installed in last night, not bad, was expecting it to be a little louder. Install was ok, purchased all the tools then I realised that 3 bolts I couldn't torque tighten properly due to my torque unable to go below 19nm. So I had to tighten but not too much, the two allan key circle clips, the graphite bracket and the sensor.
#213
If you want it louder you can take out the screw at the end of the pipe and remove the baffle, easy to reinstall if you need to....
#214
Yeah I was going to ask about that, do you guys have it in or out?
#215
I tried mine with out the db killer, sounds awesome!
It sounds just right with it in so I left it. I think you may loose a bit of HP with it out though. Dyno would tell you for sure.
2005 Suzuki SV1000R ![]() 1985 Yamaha XT608N ![]() 2012 Suzuki DL650AL2, over 13,000 miles already! |
#216
The baffler sat so tight in my exhaust that I was unable to remove it from the rear - not even using pliers. Instead I used a rod to knock it out from the other end before I mounted the exhaust to the bike. I don't feel any loss of power with the baffler out - rather the opposite.
#217
It does sound awesome with it out ...louder but not too loud....however I ride with it in since many of my trips end up being longer than planned
You have nothing to lose by trying it ...take out the screw and pull it out.. It is a bit tight in there as previously posted but it will come out... |
#219
It is somewhat louder (no idea about the db) - but even without the baffler I don't find it annoying on long/all day rides.
#220
The question is: does it become annoying for other people around?
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
