New Crashbars - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Old 12-31-2012, 11:34 AM
strompilot's Avatar
was Fireball18
Default New Crashbars
Wow!! Just mounted my Happy Trails "nerf" bars yesterday. (sorry, haven't taken any pix yet) Man are those things stout! They're not just decoration, and if the bike ever gets dropped, they look like they will protect the tank and the plastic parts. I don't, however, intend to test that theory. They went on easily and everything fit perfectly. Happy Trails even lists the proper torque values for the screws provided. Nice touch.
'09 DL650
Old 12-31-2012, 11:35 AM
Moderator++
What values did they specify? They are wrong in the service manual.
Old 01-02-2013, 06:48 PM
nelson177's Avatar
Interested in the same. Send some pics when you get a chance. Thanks.
[B]2011 DL 650[/B]
Old 01-02-2013, 10:33 PM
geoff2k's Avatar
I'm going to need some new crash guards, and while I was considering just getting another set of SW-Motechs, am interested in alternatives!
Old 01-02-2013, 10:51 PM
Also consider Altrider
AltRider: Products All Products // Bike Protection // Crashbars // Suzuki
This communication may be unlawfully collected and stored by the National Security Agency (NSA) in secret. The parties to this communication do not consent to the retrieving or storing of this communication and any related metadata.
Old 01-03-2013, 12:11 PM
strompilot's Avatar
was Fireball18
18 ft./lb. torque.
I didn't look in the service manual, but it's for a 2004--2006 650. Mine's an '09.
'09 DL650
Old 01-03-2013, 12:33 PM
Moderator++
Not bad. The service manual says 25.5lb-ft which is wrong for all years of 650. The accepted value for a typically hardened 8mm bolt is 16.5lb-ft as is stated in the DL1000 manuals for the same bolts.
Old 01-03-2013, 04:01 PM
strompilot's Avatar
was Fireball18
Here's some pix. I apologize for the quality, but it's crowded in the garage and it was just a bit cold to wheel the bike outside, and the wind is currently blowing like sixty!
As you can see, these nerf bars, as Happy Trails calls them, extend out a little farther from the bike than some other makes. They also extend up higher to provide decent protection in the even of a tipover. Lastly, the steel tubing seems to be of a larger diameter than some others I've seen, and they are powder coated with what appears to be very durable crackle finish, similar to Rhinocoating.
'09 DL650
Old 01-03-2013, 11:31 PM
Can you take the plastics off without taking the bars off?
DL650K8ABS IBA# 35551
Old 01-04-2013, 12:12 AM
strompilot's Avatar
was Fireball18
I never gave that any thought, but it looks like it can be done. Haven't had any reason to do that yet.
'09 DL650
