I have a front end clunk but where from? (and brake seals) - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Old 12-08-2012, 12:00 PM
Default I have a front end clunk but where from? (and brake seals)
My Wee has a clunk at the front. It's only when you hit a resonable bump in the road but in Yorkshire thats pretty regular.
I've had a good look around but can't find a cluprip. Nothing I know how to get at seems overly loose. So I'm just wondering, if you had a front end 'clunk' that only happened on pot holes and speed bump type stuff, where would you be looking?
Many thanks in advance.
(though on a side note, does anybody know if the seals for the rear brake on a vee 2008 are generally the same as the wee 2008? I ordered the wrong set on ebay. When I realised, I went back and ordered the right ones from the same guy. He then put them both in the same pack. I cant tell the difference between the two sets.)
Old 12-08-2012, 12:14 PM
Moderator++
They all clunk. It's normal. Both bikes use the same rear brake calipers as long as the 650 is non ABS.
Old 12-08-2012, 01:45 PM
Keith Falkner's Avatar
Default I found a scary CLUNK.
A few months ago, far from home, I heard some scary noises, CLUNKs included,
and they seemed to come from the front wheel. I parked as soon as I could,
hoisted my heavily-laden Wee-Strom onto its center-stand, and tried to find
the source of the noise. It seemed to be coming from the front somewhere.
I had visions of some sturdy piece of front brake detaching itself from the
bike and dangling into the front wheel, thus bringing me to an abrupt and
very painful halt.
I piled coat and helmet onto the pile of gear at the rear, to bring up the
front end. I rotated the front wheel and looked for trouble. Nothing was wrong.
I didn't find the cause of the noise. Everything up front was sound and solid.
You can imagine I was a tad nervous about resuming my ride, but I did just that.
A few hundred scary miles later, I reached home safe and sound.
I unloaded only what I needed for the night, and resolved to find the answer
in the morning. With the bike unloaded, it was quite obvious: the rear bolt
holding the chain guard had escaped, so the chain guard was bouncing around
on the swing-arm and making all those clunky noises. Cost to fix: 20 cents.
I have no idea why the sound seemed to come from the front end,
but I know that acoustics is a complex science, and of course the path
that the noise took was complex. Wearing a helmet makes it tough to
pinpoint a sound's source.
So have a look at your chain guard. It might be the culprit.
I don't really think it is, but you never know. Good luck in any event.
Keith
Thanks Greywolf
That's a huge help. I guess I'll have a spare set of seals when I stip the caliper down.
Old 12-08-2012, 01:53 PM
Keith
Thanks. I guess I should get round and check everything else is present and correct, not just up front. The clunk has been there as long as I remember but I've been noticing it more of late. I guess riding in the snow and ice makes you want to have more confidence in your steering and suspension.
Old 12-08-2012, 05:00 PM
jokermtb's Avatar
Sometimes the bolt that secures the fuel tank allows the tank to shift slightly on the rubber holders, causing a 'clunk' when you hit a bump big enough to jiggle the tank. Search on fuel or gas tank clunk on the internet and you'll see how to investigate this Vstrom peculiarity.
Old 12-08-2012, 06:24 PM
worst feature of the 'strom, that damn clunk.....then again, if that's the worst...
"Don't sweat the petty things and don't pet the sweaty things." ---George Carlin
2005 Triumph Sprint ST 1050
2009 XT250
2007 dl650
2002 Beta Rev 3 trials bike
2012 CBR250R
1996 TW200
2001 tt-r 125
2012 Buddy 125
Old 12-09-2012, 02:20 AM
you should also check the 2 bolts holding the headlight subframe
Old 12-09-2012, 11:13 AM
MikeB's Avatar
My chronic clunk was fixed by tightening the steering head bearings. Your situation may differ, of course.
2008 DL650A
2003 Kawasaki Vulcan 1600 Classic
"What good does it do to save the planet if humanity suffers?" -- Exxon/Mobil CEO Rex Tillerson
Old 12-09-2012, 11:48 AM
kiwi_outdoors's Avatar
Default how to test fuel tank for clunk
ride over a speed bump while strongly pressing down on top of tank with left arm (may need to stand on pegs to do this) - my clunk is my fuel tank
