Overfilling oil symptoms - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Old 12-04-2012, 12:21 PM
pso pso is offline
Default Overfilling oil symptoms
I have an 08 wee and inadvertantly over filled the oil due to a leak from the oil filter. What can i expect problem wise? Air filter problems, etc? I ran the bike a good deal in this condition(starting up in garage to keep battery up etc).
Old 12-04-2012, 12:42 PM
Moderator++
It would need to be significantly over filled to cause a problem. If in doubt, check the airbox for oil coming through the breather tubes. Starting it in the garage is a bad idea though. Water and other byproducts of combustion create acids. Unless the system gets hot enough to get rid of the water throughout, the acid will attack, particularly in the exhaust. That takes about a 20 minute ride. With no load to increase heat plus the low revs, idling takes significantly longer. Idling also doesn't charge well. Starting may take more of the charge than you put back. Get a battery tender.
Old 12-04-2012, 01:06 PM
Scott E. Bonds's Avatar
Very good advice. Battery tender for sure and push it around if you are not planning 20 minutes or more on the road.
2007 Blue SuperVee 1000
2013 Grey Super Te'ne're'
2000 Red Honda XR 400r
Old 12-05-2012, 01:58 AM
How far would you estimate you overfilled? One of the detriments of over filling the oil is over-pressurizing the crankcase thereby causing oil leaks. As the engine's RPM increases, so does the oil pressure to a leveling point. If the oil level is too high, the pressure under the piston during the downstroke can become so great that a seal is distorted and starts to leak. Once a seal is distorted, it seeps....then leaks.
'92 Honda Z50R
'94 Kawasaki KLX250 modded to 340cc's
'00 Yamaha YZ426F
'94 Yamaha 125 scooter
'05 Vespa E4 scooter
'68 Vespa VBB scooter (restored)
'06 Wee
'03 Honda S2000 roadster
Old 12-05-2012, 02:24 AM
It's unlikely to be a problem if it's only been idled.
Just get the oil level down, ride and forget.
Pete
Old 01-08-2013, 05:57 PM
Bstrom650's Avatar
What prevents you from pulling the drain plug and refilling to the proper volume - are we talking about 15 minutes here? No need to gambler...
Brian Patterson
Powell, TN
2007 Suzuki DL650A | 1996 Jeep Cherokee | 2003 Mercedes E320 | 1995 Mazda Miata
Old 01-08-2013, 10:29 PM
Mr_McBride's Avatar
+1
Correct the problem before it becomes a bigger issue.
-rodney
2012 G-Strom - White
Old 01-08-2013, 11:22 PM
s boy's Avatar
Originally Posted by rwm0268 View Post
+1
+2, I've had to let a little oil out after an overfill on my Wee.
white wee #4 (ארבע)
Old 01-09-2013, 11:36 PM
You can suck excess oil out using a syringe and a flexible tube. Easy.
It may be that your sole purpose in life is simply to serve as a warning to others.
2007 DL650 (love it)
1983 BMW R100RS (20 years and 100,000k)
1983 Honda XL185S (chases sheep around the farm)
2007 Yamaha YF400 (feeds the sheep, pulls trailers, great up river beds)
1985 Yamaha YB50 (crossed the Southern Alps on that one)
1972 Velosolex S3800 (a blonde moment, please excuse me)
1975 Honda C50 (the original step thru)
And gone are: Raleigh Runabout (x 2), Yamaha FS1E, Honda CD175, MZ Trophy, Suzuki SP370, Yamaha RD 350, Suzuki GT 750, Triumph 5TA, BSA B40, Honda 400/4, James Cadet, Honda XL 185 (but bought another one), Suzuki YF500?, Honda S90 (which I wish wish wish I still had) and a few more which the grey matter won't release at the present.
When I was a boy my parents said 'you are NOT having a motorcycle'. So I had lots.
IBA 54971
