Decelerating - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Old 11-08-2012, 12:00 PM
Default Decelerating
Coming off of an 07 SV 650S I notice when I let off the throttle on my SV 650S the bike engine holds back like it should, on the 2011 650 V Strom there are times like if I am letting off the throttle in 3rd or 4th gear. even though the throttle is closed it seems like something is not letting it decelerate and hold back like the SV does.
Chet
Old 11-08-2012, 12:54 PM
Probably a result of different gearing, different camshaft profile and the greater crank inertia (heavier flywheel) of the DL650. All of those have an effect on engine braking.
Bob A.
Current bikes:
1990 Kawasaki Ninja 250 (Rebuilt)
2011 Suzuki DL650A
Old 11-08-2012, 01:33 PM
GlenT's Avatar
Also may be emission control dependent. As you get down below 3k RPM, the emission controls may open the throttle a bit to maintain a cleaner burn.
2004 Honda ST1300
Old 11-08-2012, 03:10 PM
randyo's Avatar
most likely the idle rpm is set a little higher
engine braking is a result of pulling vacuum thru closed throttle plate, if the idle is higher the opening is bigger, and less vacuum
RandyO
IBA# 9560
07 Strom 1k (7x,xxx miles)
99 SV650 (135,006 miles)
82 XV920R
A man with a gun is a citizen
[URL="www.gbhsurvey.com"]www.gbhsurvey.com[/URL]
[IMG]http://i427.photobucket.com/albums/pp352/xv920r/VisitedStatesMap.jpg[/IMG]
Old 11-09-2012, 07:16 AM
Does that model year have a slipper clutch? Some riders don't like the engine braking that is inherent in the earlier year models. Personally, I absolutely LOVE my engine braking characteristic.
'92 Honda Z50R
'94 Kawasaki KLX250 modded to 340cc's
'00 Yamaha YZ426F
'94 Yamaha 125 scooter
'05 Vespa E4 scooter
'68 Vespa VBB scooter (restored)
'06 Wee
'03 Honda S2000 roadster
Old 11-09-2012, 08:35 AM
randyo's Avatar
remember also that the V-strom is a heavier bike and will not slow down as quickly with the exact same engine, but I still think the idle is 25 or 50 rpm higher
RandyO
IBA# 9560
82 XV920R
Old 11-09-2012, 08:58 AM
If I had to guess the way it feels when I am letting off the throttle it may be emissions related, can the emissions be removed or is not a good idea on the strom, when I decelerate it does it for a second or two and something in the emissions or computer that is making the engine increase the rpms ever so slight for about 2 seconds and then it works normally
Chet
Old 11-09-2012, 10:28 AM
GlenT's Avatar
How are throttle cables? Does the throttle rotate easily and return immediately to the stops when released?
The emissions stuff can be fairly complex. I believe that there are stepper motors in the throttle bodies that are controlled by the fueling computer with input from the O2 sensor. Probably not something you want to mess with.
2004 Honda ST1300
Old 11-10-2012, 01:54 AM
I had a similar thing, I'd close the throttle, engine braking would kick in but then I'd have little surge for a second or two and then back to engine braking. Turned out he air filter needed changing (it had done 17,500km). I changed it and no more surge.
Not being hampered by any great knowledge on the subject my reasoning goes something like this:
I close the throttle, the engine slows down, the semi clogged air filter lets less air through than it should resulting in a richer mixture, the gremlin box says 'shiver me timbers we're polluting the atmosphere' and opens the throttle a little then everything settles back down to where it should be.
But thats just my theory..
It may be that your sole purpose in life is simply to serve as a warning to others.
2007 DL650 (love it)
1983 BMW R100RS (20 years and 100,000k)
1983 Honda XL185S (chases sheep around the farm)
2007 Yamaha YF400 (feeds the sheep, pulls trailers, great up river beds)
1985 Yamaha YB50 (crossed the Southern Alps on that one)
1972 Velosolex S3800 (a blonde moment, please excuse me)
1975 Honda C50 (the original step thru)
And gone are: Raleigh Runabout (x 2), Yamaha FS1E, Honda CD175, MZ Trophy, Suzuki SP370, Yamaha RD 350, Suzuki GT 750, Triumph 5TA, BSA B40, Honda 400/4, James Cadet, Honda XL 185 (but bought another one), Suzuki YF500?, Honda S90 (which I wish wish wish I still had) and a few more which the grey matter won't release at the present.
When I was a boy my parents said 'you are NOT having a motorcycle'. So I had lots.
IBA 54971
