Info on SW Motech crash bars/skid plate installation? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Old 11-07-2012, 01:21 PM
Default HELP NOW....Motech skid plate installation?
I finally received my used set of crash bars and skid plate. Greywolf was kind enough to supply me with instructions on the crash bars. They were easy and are on now. There are no instructions for the skidplate and alot of different bolts, washers, rubber grommets, and a couple weird shaped things that look like the screws slide through them (maybe for the front attachment?) Does anyone have their directions they can post, or take pictures of the mounting points, so I have an idea of how this thing attaches. If I had directions, I am sure it would not be too hard, but without them I have no idea. I am in the middle of this project, so if anyone can help asap, you would be the
Old 11-07-2012, 03:13 PM
heffy's Avatar
Originally Posted by Nightstrom View Post
I found a set that were used and suppossed to be in new condition. I will be receiving and hopefully installing this weekend or so. I dont believe he still had the instructions for installation. If anyone has those still, could you post them for me or send me in the write direction. I am guessing that it is mostly straight forward, but I want to make sure that the bolts, washers, and anything else goes in the correct placement.
I'm not sure if I still have the directions, but, I will look. Or we could meet up and you can look at mine. I'm in SW Indianapolis.
Requires ability to effectively deal with the morbid, the macabre, the repugnant, the abnormal, the morose, the psychotic, the neurotic and the otherwise unpleasant or unusual facets or results of human behavior.
2007 DL650 Blue (regretably gone)
2011 DL650A Black
Old 11-07-2012, 03:40 PM
Moderator++
http://static.twisted-throttle.net/m...zuki.DL650.pdf
Be aware the torque specs for the mounting bolts in the Suzuki manual are wrong. The 8mm mounting bolts should be set to 23Nm or 16.5lb-ft.
Old 11-07-2012, 09:14 PM
As always, thank you Greywolf. Heffy, I may need to check out your skid plate, etc. This weekend may be a good opportunity with a little warmth coming in
Old 11-09-2012, 07:47 PM
Ok, I changed the original post, so if you can re-read it and help me out, I sure could use it. Crash bars are on, now waiting for help on here so I can get that skid plate on. Oh, and I have the OEM factory center stand, if that makes a difference?
Old 11-09-2012, 09:17 PM
UPDATE: I looked at some pics around the site, and I could see basic things. I realized that I didnt have the back mounting plate. The box everything came in was crazy full of foam peanuts. I dug through and thought, knowing my luck, something is probably lost in the sea of foam. So I neatly set it in the trash bin. Pulled it out just now and started going through it, and finally found that piece. Now I sat down and looked around the bike and the hardware, and its starting to make sense. I think I have it ready to go now. Feel welcome to post pics of your mounting points on the skidplate itself, but I think I'm good to go now
Old 11-10-2012, 02:32 PM
Stalky Tracker's Avatar
If you are still looking for the SW Motech skid plate instructions: http://static.twisted-throttle.net/m...96_10001_s.pdf
The oem centerstand posed no problems when I installed the SW Motech skid plate.
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Old 11-10-2012, 11:10 PM
Man, I wish I would have had that last night.....lol. Hopefully this post will help someone else in the future. Looking at the picture, I installed it perfectly. Considering it was just a zip-lock bag full of bolts, washers, grommets, etc, Im happy I figured it out without any assistance. PITA, though. Its funny how decent instructions can make a job so easy, that otherwise is would be a pain.
Old 11-12-2012, 01:19 AM
Default Skid plate
I just installed the crash bars and skid plate. The instructions are not very good, but I think I still have them. PM me and I will give you my phone number, if you still need the help.
Old 11-19-2012, 01:46 PM
twistedthrottle's Avatar
Twisted Gear Specialist
One thing to keep in mind with almost every product that Twisted Throttle sells you can visit the product page and click on the tab named "INSTALLATION INSTRUCTIONS". On this tab you will be able to download the original instructions as a PDF.
TwistedThrottle.com Toll-free 855-255-5550
Follow us on YouTube, Facebook and Twitter!
