Silicone hose kits? - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
  #11
Old 12-31-2012, 07:31 PM
Originally Posted by Boit4852 View Post
Mt Wee is now beyond the point where it needs to have the coolant hoses replaced. I have googled silicone hose kits to no avail. I found a site that offers universal hoses but there are 2 issues with this. First, I don't know my hose I.D. size. Secondly, I'm not sure if I can make their generic bends work without causing a kink. Are you Wee owners using OEM hoses or have you found better hoses?
First off, why do you say they NEED replacing? Just because of the manual's recommendations?
Secondly, the best way to figure out what size hose you need is to go measure. Isn't that what you always do when you need to know how big something is?
Old 01-01-2013, 10:11 AM
MikeB's Avatar
My hoses were sound, but I replaced them and the seals which are used to attach them to the motor, when I noticed a leak in there.
The seals were pretty much liquified. I upgraded the clamps while I was at it.
It can be done without removing anything.
A concern was losing the recessed seal shrapnel into the motor,but it had to be done as I had lost integrity of the coolant system which could lead to motor damage.
I havent seen or smelled lost coolant since I replaced the seals and the bike has seemed to run cooler- 2 bars on cool days
OK, there are head-scratchers and then there is this. I've had coolant hoses off for radiator removal on two different Wees ('07 and '0 and I have not encountered anything remotely resembling a "seal." In fact, I have never encountered a seal in or near a coolant hose on any type on any car, truck or motorcycle. What am I missing?
And only two bars? Both of my bikes have shown a steady three bars when running at highway speed in temps from freezing to stinking hot. It's hard to believe that there is so much variance in these mass-produced bikes.
2008 DL650A
2003 Kawasaki Vulcan 1600 Classic
"What good does it do to save the planet if humanity suffers?" -- Exxon/Mobil CEO Rex Tillerson
Old 01-01-2013, 10:27 AM
Moderator++
It's not uncommon for Wees to drop to two bars in cold or cool and rainy weather. There are a number of variables including the thermostat, temp sensor and display that aren't exactly precision instruments.
There are no seals on the hose ends. The hoses just slip over the spigots and get clamped in place. A previous owner may have dumped radiator leak sealant in the coolant when tightening the clamps usually takes care of leaks.
Old 01-06-2013, 04:22 PM
Default seals orings spigots
Mike
The seal I referred to is Suzuki part 09280-18009 which they call an o-ring.The hoses from the thermostat to the motor (17853-19f00) are mounted to fittings which have a seal or o-ring between themselves and the motor.THere is only a hole in the motor otherwise. The fitting is attached via a single bolt.The attachment is weak and If the seal deteriorates it invites a leak.
Looking at the radiator hose section of the microfiche is worth a thousand words.
Also, for whatever reason the coolant bars lingered longer at 2 afterward, rather than thier typical three.Then again the fuel bars are also schewed.
06 dl650
Old 01-06-2013, 05:08 PM
Moderator++
Suzuki part 09280-18009 is number 7. It seals part #6 to the engine. #6 is aluminum and referred to as a connector rather than a hose.
