4 Piston Brake Calipers Installed on ABS Bike - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
  #11
Old 05-12-2011, 02:08 PM
Moderator++
The difference was the extra stopping power. ABS does nothing to prevent a rear wheel lift. It doesn't even function when the front wheel is going under 3mph so you can get the rear wheel well up in the air and the end of the stop.
Old 05-12-2011, 04:12 PM
Kcwiro's Avatar
Nice write up...
Now the real test I would love to see is a bike similarly setup with 4 pots vs 2 pots. For me when it comes to replacing / upgrading parts on my motorcycle I follow the same rules I follow with the car I rally.... until the stock part breaks use it until it does | there are noticable exception such as HID upgrades so don't bother point that one out anyone hehe
Still good to know this upgrade is possible with what appears to be little fuss
-Scott
2009 WEEStrom ABS - 39K and still ticking - rehoned head at 35k...
1980 GS750E (first bike)
Old 05-12-2011, 04:14 PM
brianjonesphoto's Avatar
Off Wee-ing in the woods
Originally Posted by Kcwiro View Post
Nice write up...
I'm usually the same way, but the 4 pot upgrade is a vast improvement in stopping power and general brake feel compared to stock. Well worth the $80ish I spent to do it.
DL650AK7 totaled 7/24/08 5,000 Being reborn as the ADV-Strom
99 DR350SEx
Wife's rides 06 F650GS, 02 Kawi Super Sherpa
DL650AK7 totaled 7/24/08 21,000 miles
Stromtrooper offroad club #20
"Aerodynamics are for people that can't build engines"-Enzo Ferrari
"Wave to Cows, They Taste Good"-Stolen from Brendan, adapted by me
Old 05-12-2011, 08:48 PM
halfast3's Avatar
Originally Posted by Ruggybuggy View Post
What did you end up paying for the '06 master? I looked for about 3 months before I found one at a reasonable price in good condition. Did you end up tweaking the left brake hose? Will post pics tonight.
I gave $50 + shipping for mine. Seemed reasonable. The seller was asking $59.95. I did tweak the left hose a bit to create some slack. Didn't take much...
Rick
DL650A(K7) SOLD
'08 XT250
'12 Tiger 800ABS
Old 05-12-2011, 10:44 PM
Ruggybuggy's Avatar
I did a couple of 90kmph (55mph) stop tonight with ABS activation and without. Everything worked fine and braking was stronger with less applied to the lever. Without ABS activation (threshold braking) I was surprised at how quickly the brakes reacted and how strong the brakes felt. With ABS activation the brakes worked well and still very strong braking. I did noticed at the very end when the ABS activation quites (under 5mph), brakes grab and want to lock but this occurs when your almost stopped. I also tried the brakes on a gravel road at speed of about 30mph. At that speed I grabbed a handful of front brake and applied the rear hard. ABS activation was normal without any drama. Seemed to work exactly the same as before. The more I ride with this setup the more I like it. The brakes react very quickly when you want them to but are still easy to modulate. I do expect a shorter stopping distance because of how quickly the brakes come on.
Some people are like Slinkies...... They're really good for nothing but still bring a smile to your face when you push them down a flight of stairs!
Old 12-02-2012, 07:03 PM
darkjedip's Avatar
Just scored some 4 pot Nissin calipers off eBay. 2005 f4i with 5k miles. $82 with the Honda master. Will order the brackets soon
On a riding hiatus
Previous:
1977 Bonneville T140V Project
2008 DL-650A (RIP)
2006 DL-1000
2003 Kawasaki ZR-7S
2003 Kawasaki Ninja 250
Aspiring Moto-journalist needs feedback:
http://nowheelieshere.blogspot.com
Old 12-02-2012, 08:18 PM
darkjedip's Avatar
Also, Is it necessary to change out the M/C or will the stock suffice?
On a riding hiatus
Previous:
2008 DL-650A (RIP)
2006 DL-1000
2003 Kawasaki ZR-7S
Old 12-02-2012, 08:21 PM
Moderator++
Try it and see. Some owners feel the stock 2007+ M/C makes the lever too mushy and prefer the older one with the larger bore.
Old 12-02-2012, 09:36 PM
darkjedip's Avatar
I'm a bit on the fence after reading this: http://www.vstrom.info/Smf/index.php...,11089.90.html
Interestingly, if M/C piston size is an issue, my set comes with the Nissan M/C from the F4i, which may work for the Wee. Based on the afformentioned thread, i'm wondering if the mod is safe to do with the ABS system.
On a riding hiatus
Previous:
2008 DL-650A (RIP)
2006 DL-1000
2003 Kawasaki ZR-7S
Old 12-03-2012, 03:19 PM
Stromtrooper.com Sponsor
Thumbs up
Originally Posted by brianjonesphoto View Post
Pat you are very much right on both accounts,.............the increase stopping power from the 4 pots in ables you to brake right up to the threshold of the ABS system
Hi, You are right in your observation that the 4 Piston Brake Calipers have increased your stopping power and you are now easily able to brake right up to the point of threshold braking. Your brakes are working well based on your comments.
Most bikes with good brakes, abs or not, will lift the rear wheel slightly for a moment when the brakes are applied with progressive force. This is a function of the weight and traction transferring forward. Not to worry at all.
Blair
SV Racing Parts
www.svracingparts.com
b.layton@svracingparts.com
