How to extract dropped items from inside cowl area? - Page 3 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
  #21
Old 03-24-2011, 08:30 PM
The Hale's Avatar
My question is, How does one learn all of these little pitfalls BEFORE one of their windshield bracket bolts falls into this area and they spend hours researching how to remove the front fairing unsuccessfully until they throw their hands up and say "Damnit, I'll just search for 'dropped bolt headlight' and see what comes up."
I'll try the telescopic magnet.
2009 Orange 650
Old 03-25-2011, 06:56 PM
The Hale's Avatar
WOOHOO!
The $1.99 telescopic magnet did the trick!!!!
2009 Orange 650
Old 03-25-2011, 07:50 PM
Stoopy's Avatar
Very glad it worked for you!
Sadly I tend to use stainless screws which of course aren't attracted to magnets....
"Ignorance is a powerful tool if applied at the right time, even usually surpassing knowledge." - E.J. Potter
Old 03-26-2011, 08:36 PM
guitarhack's Avatar
I have dropped all kinds of crap down there. Usually the telescoping magnet thing did the trick - but not always - it doesn't go around corners well, and you have to use the braille system to go about it - it's dark down there.
I'm not above just giving up. Allen wrenches have been known to mysteriously show up on the driveway after washing my Wee.
If you are really hard-core, you could use the missing washer as motivation to finally check your valve clearances. You can give the plastic a good cavity-search as you tediously take it all off.
Old 03-26-2011, 08:50 PM
Moderator++
How about a report on the most expensive item found in there? Mine was a $9 security screwdriver for a Garmin Zumo GPS locking screw.
Old 03-26-2011, 09:11 PM
BigMan73's Avatar
I just lost today a MadStad rubber bumper there (worth 1c?) - no magnet can rescue it.
That dark cave is creepy..
I think, in retrospective, that the best solution to first seal it with something before starting to work there.
2014 Northeast V-Strom Rally! (NEVA 2014), Aug 1-Aug 3, North Adams, MA
Stromputer - A V-Strom Computer and display
2011 DL650 ABS ( "White Pearl")
Stromtrooper Wiki!
Old 03-27-2011, 08:27 AM
The shape of the lower fairing causes it to open a portal to an alternate dimension
Nothing is comming back
Old 03-27-2011, 08:44 AM
LoneRider7722's Avatar
Originally Posted by janiceclanfield View Post
Turn the bike upside down and shake it 'til the pieces fall out.
You're welcome.
Hee Hee Hee....Janice I like that idea.....Brillant.....
Lead, Follow, or Get Out of the Way!
2009 DL 650 ORANGE
2000 KL250 SUPER SHERPA
1981 GS 550 TX
Lots O Parts!
lonerider1956.blog.com
Old 03-27-2011, 08:50 AM
Originally Posted by blue flame View Post
Spring's a coming, Pal ! Just c'mon up to VT and ride around a while during frost heave season, and those tid-bits, and probably many other things, will be outta there before they know what hit 'em !
Yep That's the Maine way too......
2009 DL 650 ORANGE
1981 GS 550 TX
Lots O Parts!
Old 03-27-2011, 09:51 AM
andreas's Avatar
Get a felt pad like the one you stick to the chair legs. I have a set at home and a 3x4 inch pad that I cut to whatever I need. Also great to help stop rattles.
FB MEMBER #133 - 2008 Wee
