I have a front end clunk but where from? (and brake seals) - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Old 12-08-2012, 12:00 PM
Default I have a front end clunk but where from? (and brake seals)
My Wee has a clunk at the front. It's only when you hit a resonable bump in the road but in Yorkshire thats pretty regular.
I've had a good look around but can't find a cluprip. Nothing I know how to get at seems overly loose. So I'm just wondering, if you had a front end 'clunk' that only happened on pot holes and speed bump type stuff, where would you be looking?
Many thanks in advance.
(though on a side note, does anybody know if the seals for the rear brake on a vee 2008 are generally the same as the wee 2008? I ordered the wrong set on ebay. When I realised, I went back and ordered the right ones from the same guy. He then put them both in the same pack. I cant tell the difference between the two sets.)
Old 12-08-2012, 12:14 PM
Moderator++
They all clunk. It's normal. Both bikes use the same rear brake calipers as long as the 650 is non ABS.
Old 12-08-2012, 01:45 PM
Keith Falkner's Avatar
Default I found a scary CLUNK.
A few months ago, far from home, I heard some scary noises, CLUNKs included,
and they seemed to come from the front wheel. I parked as soon as I could,
hoisted my heavily-laden Wee-Strom onto its center-stand, and tried to find
the source of the noise. It seemed to be coming from the front somewhere.
I had visions of some sturdy piece of front brake detaching itself from the
bike and dangling into the front wheel, thus bringing me to an abrupt and
very painful halt.
I piled coat and helmet onto the pile of gear at the rear, to bring up the
front end. I rotated the front wheel and looked for trouble. Nothing was wrong.
I didn't find the cause of the noise. Everything up front was sound and solid.
You can imagine I was a tad nervous about resuming my ride, but I did just that.
A few hundred scary miles later, I reached home safe and sound.
I unloaded only what I needed for the night, and resolved to find the answer
in the morning. With the bike unloaded, it was quite obvious: the rear bolt
holding the chain guard had escaped, so the chain guard was bouncing around
on the swing-arm and making all those clunky noises. Cost to fix: 20 cents.
I have no idea why the sound seemed to come from the front end,
but I know that acoustics is a complex science, and of course the path
that the noise took was complex. Wearing a helmet makes it tough to
pinpoint a sound's source.
So have a look at your chain guard. It might be the culprit.
I don't really think it is, but you never know. Good luck in any event.
Keith
Thanks Greywolf
That's a huge help. I guess I'll have a spare set of seals when I stip the caliper down.
Old 12-08-2012, 01:53 PM
Keith
Thanks. I guess I should get round and check everything else is present and correct, not just up front. The clunk has been there as long as I remember but I've been noticing it more of late. I guess riding in the snow and ice makes you want to have more confidence in your steering and suspension.
Old 12-08-2012, 05:00 PM
jokermtb's Avatar
Sometimes the bolt that secures the fuel tank allows the tank to shift slightly on the rubber holders, causing a 'clunk' when you hit a bump big enough to jiggle the tank. Search on fuel or gas tank clunk on the internet and you'll see how to investigate this Vstrom peculiarity.
Old 12-08-2012, 06:24 PM
worst feature of the 'strom, that damn clunk.....then again, if that's the worst...
"Don't sweat the petty things and don't pet the sweaty things." ---George Carlin
2007 dl650
2002 Beta Rev 3 trials bike
2009 KLX250S
2000 Super Sherpa
1996 TW200
2009 Ruckus
2001 tt-r 125
Old 12-09-2012, 02:20 AM
you should also check the 2 bolts holding the headlight subframe
Old 12-09-2012, 11:13 AM
MikeB's Avatar
My chronic clunk was fixed by tightening the steering head bearings. Your situation may differ, of course.
2007 DL650
"Who the hell wants to hear actors talk?" -- Harry M. Warner, Warner Brothers, 1927
Old 12-09-2012, 11:48 AM
kiwi_outdoors's Avatar
Default how to test fuel tank for clunk
ride over a speed bump while strongly pressing down on top of tank with left arm (may need to stand on pegs to do this) - my clunk is my fuel tank
