tank bag - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Old 11-22-2012, 08:29 PM
Default tank bag
What kind of tagnk bag are you using?
I am use to using one on my Kawi but it is mostly used as a map bag.
Thanks for your help
WW
Old 11-22-2012, 08:57 PM
I'm using a Cortech super 10 magnetic tank bag, works great.
Old 11-22-2012, 09:01 PM
chicago's Avatar
Bags-Connection "Enduro" EVO strap-on Tankbag - KLR650E, '08- dual sport - Kawasaki - Shop by Bike - TwistedThrottle.com
13 DL650, 03 DR650, 95 DR350
Old 11-22-2012, 09:19 PM
Old Mike's Avatar
Default tank bag
Are the magnets storng enough to keep it in place and are they positioned in the correct place to grab the tank properly?
Keep The Rubber Side Down!
2006 DL650
2004 DRZ435S
1999 YZ400F
andreas's Avatar
Wolfman "Explorer Lite" Tank Bag , Got it at PWD. This is my 5th tankbag and hopefully last, Great form fitting bag, large map pouch, Rain cover.
FB MEMBER #133 - 2008 Wee
Old 11-22-2012, 09:28 PM
Stalky Tracker's Avatar
I started with a Cortech Super Mini magnetic tank bag. I have now switched to the new Bags-Connection Engage EVO quick-lock tank bag that uses the B-C gas cap ring to mount and secure it. The bag is a tad small but has worked fine so far and I really like the mounting (and dismounting) system.
I also got the map case for mounting on top. Which has worked well too, though it is not waterproof. Probably why the Engage bag comes with a waterproof cover that will cover the map case too.
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Old 11-22-2012, 09:49 PM
I have used a GEARS very inexpensive tank bag for 5+ years it holds on fine but don't over stuff it as the zippers are not good it is OK for daily commuter travel and is only water proof if the cover is on but is OK for the job. It holds on fine. I don't think any tank bag is going to fall off and if there is a concern any observant rider will or should see the problem long before it becomes a big problem
Old 11-22-2012, 11:05 PM
swoody126's Avatar
+1
quite satisfied w/ the way it rides & works
rain cover has done a real well job, too
sw
Everyone crashes. Some get back on. Some don't. Some can't.
steve
'05 WEE (LRW)
'99 DR TREE FIDDY SEX
plus several BRAND X
Old 11-23-2012, 01:50 AM
debeerm's Avatar
I have the Oxford 1st time tank bag (ironically it is my first tank bag). It has magnetic fitting and a large see through pouch for a map. What I though was really nice was that I could work on my touch screen HTC through the pouch. It has a 18L capacity which is not much but it works well for storing gloves, keys, maps, sunglasses and wallets. It also has a see through rain cover. See the link below:
OXFORD TANKBAGS | TANKBAGS | MOTORBIKE BAGS | MOTORBIKE ACCESSORIES | BIKE ACCESSORIES
2006 Wee (Cherry Red) Farkles and Nice to have's: Reflective rim decals, Heidenau K60 Scout tires, 45L Givi Top Box, Givi AF260 Screen, Oxford Tank Bag, 2 x USB Power Ports, Rick's Fork Brace, more to come...
2009 Sam 200cc scrambler (Sold)
Old 11-23-2012, 05:33 AM
I have this.... so far Itīs ok.
Easy to mount and no scratching surfaces when refuel
Strong fabrics
GIVI_TANKLOCK System - YouTube
