#11
I'm surprised the car tire doesn't handle better off road? You think its because your car tire you are running is more sport oriented tire? I think Randyo and who ever else is running that winter tire up in the North with some pretty good lugs on the side is actually reporting some pretty good off-road traction? But of course, we all play on different types of roads in different parts of the US. Before I switched to the Shinko's my favorite combo was a Anakee front and a Tourance Rear. The Anakee didn't cup as easy as the Tourance and didn't have that "numb" feeling at the end of its life. I've got Anakee's on the bike right now, but only because I got sweet deal on a used set and still had a used rear I needed to run out.
BlueLghtning - Follow me on my Spot Messenger --> (My Pictures) '09 DL650 w/25k miles Sold: '04 DL650 w/40k & '04 DL1000 with 30k, 07 DL650 with 20k, 08 DL650 w/5k. All lower 48 states + Alaska completed between 2006 & 2008 ![]() Candian Provinces |
| Sponsored Links | ||
Advertisement | ||
#12
parently you didn't get the jest of Judd's post don't confuse handling with traction, the car tire gets phenominal traction off road, almost too good, the problem is its wider and doesn't fit in the common single track rut , the tire catches the edge of the rut or a rock that only catches the edge of the tire, makes your back end squirm/bounce around a bit low speed handling makes you wonder why yer runnin a car tire, soon as you get any speed everything changes
RandyO IBA# 9560 07 Strom 1k (7x,xxx miles) 99 SV650 (135,006 miles) 82 XV920R A man with a gun is a citizen A man without a gun is a subject www.gbhsurvey.com http://i427.photobucket.com/albums/p...dStatesMap.jpg |
#13
#14
Yep,,,,,, Randyo hit the nail on the head. Traction with the car tire, even my sport oriented tire is fine, but that huge width seriously sucks in rough stuff even when aired down to as low as 15psi {worsens with higher PSI}. As you know, I don't do single track on the DL but I do like playing around on terrian that is a challenge. Have you ever rode the backside of Trey Mountain just north of Helen? Or maybe 28/2 Nimberwill into Old Bucktown {actually, they recently ruined that section by grading it but it used to be fun}, or from there up the backside of Amicolola Falls? They are all forestry service roads but are rarely maintained and sorta rough and challenging on this size bike. Rocks, and ruts from the 4x4s playing and such. Not a challenge on a DRZ or even a DR650 but a serious challenge on a DL and the water breaks on Trey are downright fun.
In that type terrian, the car tire sucks because it's constantly upsetting the bike basically finding and reacting to every largish rock and rut it can possibly find. Now, on the fairly groomed dirt roads like 42, 28 and the part of Trey that parallels 75 the car tire does fine. Maybe better than the 705 possibly, for sure it was better than the Tourance. ![]() I really wish I could find a smaller width car tire to run, especially something like a 175-185 width with a aspect ratio in the 55 range. While I'm dreaming, could I find this in a high void tread type winter/snow tire? ![]() Damn Dan,,,, I'm going off the deep end man. I've gone from dreaming about perfect motorcycle tires to where now I'm dreaming of better car tires to put on the back of the Wee Turd! ![]() ![]()
Endeavor to Persevere Blue Skies Coming! Pics-http://s563.photobucket.com/home/Jud...heon/allalbums |
#15
![]() don't feel lonely, I'm thinkin my next tire will be a studded Nokian Hakkapelliitta
#16
#17
I bought a Falken something or another. It's a 205/50/17 and I bought because that's what I found nearby for cheap. I would recommend something else as it has a very pronunced rim protector molded into the bead and it makes mounting the tire a bear to do. I wanted to make sure it would even work and figured I at least had a possibility of returning it if I couldn't get it mounted up. I got it mounted and learned a pretty cool trick to make life alot easier but now with some experience, I think I would get a winter/snow tire. Might cost more but it should give better traction off road due to the tread design.
I think RandyO has done just that and I actually read through his posts before trying mine. ![]() Pics- ![]() ![]() I was honestly surprised by how good it worked. Like I said, I don't care for how it handles really rough stuff but if your DL rarely hits the rough stuff, I can't see a better option unless you really rail the corners alot and if that's the case, Pilot Powers would be more in line then.
#18
Tire thread alert
I won't be going darkside but I will be replacing Anakee 2 rear with A pilot road 2 while keeping Anakee 2 front.
Link Click Here >>> 2013 Northeast V-Strom Rally! FILL OUT NEVA MEAL POLL If your attending Also in events 8/2/2013 |
| Sponsored Links | |
Advertisement | |
| Tags |
| guide, tires |
| Thread Tools | |
| Display Modes | |
