I searched but cannot find the answer....
I am replacing my chain and sprockets and am wondering if anti seize is recommended for the countershaft sprocket nut? I have changed two before (SV 650 and the Strom to 16T) and did not use anti seize. Removal of the nut today was nothing less than a B*tch! Yes I bent the washer back down first. After busting my stones last night trying to break it loose,I used Kroil and let it set overnight. Today it took some doing, but I was able to get it loose. Do any of you use anti seize? TIA
ATTITUDE IS EVERYTHINGFlat Black 08' DL650. Lots of goodies |
| Sponsored Links | ||
Advertisement | ||
#2
No. High strength thread locker such as red Loctite is specified. New sprocket nuts have it pre-applied. Heat can be used to defeat it but a long breaker bar or an impact gun are the usual removal tools.
#3
What GW said plus I take them off with the chain still on and the rear brake locked.
'07 WEE-HAAAA! Blue, loaded & sweet I'll know where I'm supposed to be when I get there. |
#4
Thanks Pat, glad I asked first.
I used a breaker bar, but it was still tough....no impact wrench available... yet.
#5
Comes off easy with an impact. I never have tried it any other way.
Kevin L2 DL650A The Orange Machine K7 DL650 Hi Yo Silver R.I.P! |
#6
FLAMER DISCLAIMER - The opinions of this writer do not necessarily reflect that of this website, its sponsors, or readers. So yes, yours may be different, but that's OK!
#7
I have now changed Hmmm...8?...10? or more countershaft sprockets in 42, no count again...44years! I remember to this day changing the sprockets of my first bike, a worn out Yamaha YD3. My experience was similar to your post, was I mad. Just 18years old, my first attempt to undo was the wrong way which added to the..Joy? With borrowed tools, 'cos I didn't own any then, I slipped a meter (3') length of pipe over the socket handle. With my dear old Mum ducking low and holding the pipe, I took a swing at it with the back of an axe! Off it came just in time to save me from an internal explosion. OH! I do remember!
To this day I never over torqued this nut, just a solid twist on the wrench and always folding down the tab washer. I never experienced a problem from this method. I once bought a very cheap but good little Yamaha 500 DOHC about a 1976 model (TX500?) with a spare engine as the gear box was shot, jumping out of first gear at every attempt. A good wash and an inspection found it was only a v loose countershaft sprocket. On tightening it up I had a perfect $500 bike. One learns every day. Saturn 5...the heavy lifter |
#8
Mine came off using a 1/2 inch drive socket wrench. I put a foot on the brake and leaned over the seat. I have an impact wrench but did not need it. I am getting ready to switch from the 16 to a 17 tooth. The 16 lowered the rpms but no real change in mileage. Good for highway but more shifting needed on the daily commute.
Vstrom 650 ABS |
#9
The local shop put it on with an impact wrench and I suspect it was overtorqued.
'12 Guzzi Stelvio NTX '09 DL650 ABS (Sold) |
#10
I use the pipe through the wheel with padding as to not scratch anything. The breaker bar worked but it took alot of oomph to get it to break free. I did not overtorque it when I put the 16 tooth on...maybe I am just getting weaker with the added years
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
