I received my Stebel Horn kit from PWD yesterday and installed it. It was surprisingly easy. Just took about two hours because I was fishing the cords through and wanted to loop the cords that connected to the stock wires to go around the stick horn to left them up a little more. (Big hands, little space and warm engine didn’t help) Once done it works fine, I feel it’s a little low (but I didn't lay on the horn button… just tapped it a few times).
My question is I have the air tub zip tied a few wires next to the fuses (I think this is safe.) But where did you attach the relay. All the pictures show it attached to the plastic under seat holder but that would be for non-ABS models. The area for me has ABS fuses there. Right now I have the relay zip tied to the strap holding the battery down until I find a better spot.
2011 SUZUKI DL650 V-Strom ABS/Pearl Mirage White Farkles: Aprilia Tuono mirrors / Pat Walsh Design Super Brace / DL1000 Seat / Givi engine guards / Madstad Bkt w/ OEM or Givi Shield / PL532 & E41nn / EB PC-8 - 2x power outlets - Datel Voltmeter - Stebel Horn with PWD setup - Digital Slim H4-3(9003) Bi-Xenon HID - 1157 LED Brake lights Shiro Nakama Hachi
| Sponsored Links | ||
Advertisement | ||
#2
I put the Stebel horn relay where the old horn was but I have two relays under the seat. One is for a fuse block and the other is for the brake light connection to cancel the cruise control so there are places to put relays in the area. One is bolted to the front of the tray on the right in the picture (the left side of the bike. The other is to the left of the box labeled FUSE in the pic. It just has the mounting plate sitting in an appropriate space and stays in place nicely. There are two light blue 90 degree connectors easily visible on that relay.
#3
Mine's velcro'ed to the inside of the left cowling, but I wired my own, so your kit may or may not facilitate that. That's also where I ran my intake hose, because that's where I found the least evidence of dust incursion. Under the seat is definitely not a dust-free location, in my experience.
![]() '08 Wee |
#4
My pic is proof.
#5
Looks worse'n mine, actually (which is saying a lot).
![]() '08 Wee |
#6
![]() '08 Wee |
#7
#8
Where did you mount the actual horn? I just got a Stebel Air Cannon. My Wee has SWMotech guards and skid pan and I don't see too many spaces for mounting the horn within the various frames, pipes, hoses and motor surfaces. Any suggestions? Thanx
#9
Stromputer - A V-Strom Computer and display - PCB sent to manufacturing! --------------------------------- 2013 Northeast V-Strom Rally! 2011 DL650 ABS ( "White Pearl") ![]() -------------------- Stromtrooper Wiki! |
#10
The Pat Walsh kit does work with the old-style SW Motech bar; I have both. I don't yet have a skid plate, but I can't see how that would interfere.
![]() '08 Wee |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
