#11
Plug, play, and forget it. I have used them on cars, trucks, atv, and bikes. They always outlasted the tire.
K7 Wee ( Stormy ) Matt
| Sponsored Links | ||
Advertisement | ||
#12
If I'm on the road and have a flat, I use a normal string-type plug to get home. Then, depending on the life left in the tire and the type of hole the nail made, I will either remove it from the rim and plug it from the inside with a patch plug (lots of life left, straight in type of hole) or discard it for a new tire (not much life left and/or a large, jagged hole in the carcass).
'12 Guzzi Stelvio NTX '09 DL650 ABS (Sold) |
#13
I plugged probably over 100 tires. All with the sticky worm type and a little rubber cement that comes with the kit. Currently have almost 10k on a plugged stock rear tire.The kit will be 6-10 bucks depending where you get it.
2007 DL650 Gray |
#14
I heard all the garb on previous posts about the dangers of plugging a hole... all crap!!! I agree with everybody that plug, play and forget. I picked up a nail only a few hundred miles into owning my Strom. it was plugged with a sticky string, cut down to fit, and remained on the bike until I wore the tread out about 6K later. I keep a patch kit and a pocket compressor under my seat and they all fit VERY nicely, tucked to the rear. It's actually a beautiful sight
![]() 2007 DL-650 1996 H-D Road King |
#15
I'm almost in the plug, play & forget camp
remember to monitor air pressure & inspect carcass a couple days, a bit more than normal if for some reason, the plug has damaged the cords,you should know shortly, no leaks ir funky bubbles in the tire, then forget, if there are, replace only one time in I don't know how many tires have I had to replace a tire when I first plugged it, the tire reacted normal, increasng in pressure as I rode (heated it up) but when it sat overnite, it would loose air, when riding, it would not loose air, in the 2nd day(300miles or so), a separation in the tread/carcass started to develop
RandyO IBA# 9560 07 Strom 1k (7x,xxx miles) 99 SV650 (135,006 miles) 82 XV920R A man with a gun is a citizen A man without a gun is a subject www.gbhsurvey.com http://i427.photobucket.com/albums/p...dStatesMap.jpg |
#16
Another option to consider when installing a new tire. There is also a video where they use an ice pick, drill and run over a board full of nails and then ride away.
Tire Sealant | Tire Protection Systems for Motorcycle, Automotive, ATV and Heavy Equipment - Ride-On Tire Sealant
13 DL650, 03 DR650, 95 DR350 |
#17
The Ride-On tire sealant sure looks interesting has anyone here used it? The LED valve caps also.
DL650k9 Grey/Silver |
#18
I had a flat on a new tire, it was the rear, plugged and rode out the life of the tire with no issues. I would keep close eye on the tire pressure.
#19
Ride-On also helps balances the tires. So I no longer balance them and haven't noticed any adverse affects. YMMV
2006 Suzuki V-Strom DL650K 1986 Honda Shadow VT700C 1974 Suzuki TM-250 1966 Triumph Bonneville T-120R 1965 Suzuki 80 |
#20
Thanks. I've wondered what it would do to the balance. I'll probably get a couple of cans to carry when I'm on a trip. Has any one used the LED pressure sensors? I like the idea of an alarm when the pressure gets below 4 psi from the initial pressure fill.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
