Hi Y'all fellow Wee Strom Riders.
I've just had a massive rebuild and got everything back together. I'm trying to get the front brakes to bleed. Have used a bleeding kit and the brake fluid runs through but the lever is still spongey as hell and I can't get any braking. It was a complete fluid change so air has got in to the system. I'm not sure if it makes a difference but mine is the ABS model as well. Can anyone offer any advice on how to get the brakes back to normal. Cheers
| Sponsored Links | ||
Advertisement | ||
#2
ABS doesn't make a difference in procedure. Most likely the air is in the master cylinder area. Blair at SVRacingparts has a master cylinder banjo bolt with a bleeder screw that some people have found useful.
Pat- 2007 DL650A was ridden to all 48 contiguous states. 2012 DL650A is just getting started. Nicknames for posting ease on my part, Vee = all DL1000s. Wee = 2004-2011 DL650s. Glee = 2012+ DL650s Last edited by greywolf; 06-15-2010 at 09:00 PM. |
#3
I'm told there is some type of mechanical pump that would make the job quicker. I'm going to look into that for the next time I do the ABS brakes.
2012 XT1200Z Blue, 2012 XT1200Z Black Last edited by Dirt_Dad; 06-15-2010 at 07:10 PM. |
#4
Hey ya
Cheers for your helps peeps will try pumping again tomorrow
#5
Keep at it. It will seem like it takes forever but then all of a sudden it will come around. As bad as you think this is - it's nothing compared to my KTM 250F harescramble bike. The Brembo system on that bike is brutal to bleed.
Keep after it. |
#6
I did a fully system rebuild just a month or so ago. I needed a vacuum bleeder to get any fluid down to the calipers. After that I bled the system a bit, then took the calipers off and held them as high above the splitter valve under the triple trees. I tapped the splitter and the lines and tried to orient things so that air could move up and into the caliper. Then I remounted the calipers and bled again. After that I compressed the calipers to force fluid (and air) back into the master cylinder. I then removed the master cylinder and rotated it around while tapping it to try and move any air from the banjo bolt area into the master.
Finally, I tied the brake lever back and left it to sit for a few hours, then bled the system. Did that 3 times and now I've got full braking. Keep at it, it definitely takes a bit of work to get the ABS system bled. |
#7
Agree with others - the extra long route ABS system take means it takes a lot longer. I went through 1L of brake fluid before air is out.
Once u get brake and check the ABS light does not come on, find a safe place to activate the front ABS a bit - a couple "jast grab the brake" runs at 70km/hr seem to assist getting the last bit of air out. So is strapping the brake tight and leaving it over a couple nights. AR
Has anyone tried Speed Bleeders on their ABS Wee?
I have used them on previous bikes, including an SV650, with very good results. Makes brake bleeding a one-hand operation.
Rich D Athens, GA '09 DL650A '96 KLR250 |
#9
I have speed bleeders on my bike. I like them.
#10
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
