I currently have the throttle tamer installed. From reading on here there is a few that have said the Oxford grips fit fine with the throttle tamer. I have some questions. The heated grips fits on top of the throttle tamer right?
I used rtv to secure the Suzuki grip to the throttle tamer. Is some kind of glue used to attach the grip?
I know the adventure version does not fit, which is the one that fits ok?
It looks like there is some kind of adapter from Eastern beaver that plugs into harness straigh from the heat controller. Does anyone have more info on that.
I have both the grips and controller installed bit I am not sure how to route the cables to the battery. If anyone has done this please explain how to route the cables.
There's a heated grip connector already on the bike yes it can be a bastard to find though as it's usually tucked away and tied down. Eastern Beaver stocks the connectors, but they can be found on eBay as well.
I cable tied the wires for my oxfords to the V2 wiring harness down the right hand side of the bike.
I did the best I could without removing the fuel tank then the next time I removed the tank to service my air filter I completed the job.
When ever I wire things directly to the battery I cut a section out of the ring terminals so they are no longer a "O" but look more like a "U"
This allows you to add and remove things from your battery posts without completely removing the battery bolts, just loosen, remove or add then tighten the bolts again.
Related Threads
StromTrooper
1.7M posts
66.6K members
Since 2003
