Vibration level - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 7Likes
post #1 of 26 Old 05-14-2017, 06:52 PM Thread Starter
Vibration level
Went on a 600 mile trip this weekend to break in my new 2014. It was a carry over model and the dealer gave me a large rebate to purchase. I like it so far and have enjoyed it.
Anyway, it now has a little over 1000 mikes on it now, and on the way home I opened her up on the interstate a little. I have been taking it easy on the bike until now, and haven't really got on it too hard. At 4200 rpm, it does about 74 mph. I ran it up to 5500 and it vibrates, not Harley level, but vibrates. At 6000 it pretty strong.
Anyone have any ideas or is this, or just the nature of this bike?
I checked all the obvious things that would possibly cause vibration, motor mounts, exhausts etc... but didn't find the culprit. I already checked the various bolts during the 500 mile oil change and all were in spec.
Any thoughts?
Jlewis50 is offline
post #2 of 26 Old 05-14-2017, 07:01 PM
Mine just gets smoother. Do you have Givi crash bars? Those vibrate. Some fixes have been posted. If not, some other accessory or loose bolt is causing the vibration.
MGDIL likes this.
post #3 of 26 Old 05-14-2017, 08:48 PM
Rolex's Avatar
I have Givi bars and my bike get smoother as the RPM's go up.
Around 5000 is my happy spot.
I run a 16 front sprocket so I get a couple hundred more RPM than standard but I often find I have set my cruise control when in 5th gear not sixth because things are so smooth.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #4 of 26 Old 05-14-2017, 10:43 PM
Bugzy's Avatar
I am thinking one of your tires is not balanced, either that or you are experiencing head buffeting which can make it seem like the bike is vibrating, but really it is just your head.
Remove the windshield and see if the problem goes away, or take it to dealer and let them troubleshoot it.
Bugzy is offline
post #5 of 26 Old 05-14-2017, 11:10 PM
Stromtrooper.com Sponsor
richlandrick's Avatar
Mine just gets smoother and I have the Givi bars.
The usual suspect is the need to sinc the throttle bodies. There is a ton of information here and on VSRI about when it is needed and how to go about doing it.
Here is a You-tube video on the subject. https://www.youtube.com/watch?v=GPinq0boQsI
richlandrick is offline
post #6 of 26 Old 05-15-2017, 07:14 AM
Motor7's Avatar
Throttle bodies out of sync on a new bike? I'm thinking engine guards or re- torquing those engine mounting bolts.
Mulewright likes this.
'15 DL650XT
Motor7 is offline
post #7 of 26 Old 05-15-2017, 09:15 AM
Moderator++
A TBS was a common need on the Vee. It shouldn't be on the Vee2 though. A Vee2 TBS is an idle air screw adjustment and won't affect vibration while riding anyway.
realshelby likes this.
greywolf is online now
post #8 of 26 Old 05-15-2017, 09:45 AM
There is a harmonic vibration in these engines in the 5600-5800 rpm range. Worked on that when developing clutch baskets and found it is just an crank/piston vibration. Might seem bad considering how smooth these bikes can be at other rpms. If smooth under 5000, and ok over 6000 rpm I would not be too concerned. Get some miles on it and grow used to the bike. You are not going to spend a lot of time over 5000 rpm on these anyway.
WERKS Quiet Ride windshields for 2012+ DL 650-transform your V strom. Nothing compares.
Have questions about the Quiet Ride or clutch in your DL or SV 1000? E-mail Terry info@werksparts.com
realshelby is offline
post #9 of 26 Old 05-15-2017, 12:10 PM
I would agree with the possible tire balance. My 2014 Vee is smooth as hell.
steve85248 is offline
post #10 of 26 Old 05-15-2017, 01:00 PM
Gogodammit's Avatar
I wonder if it could be how the dealer assembled the front tire on out of the crate???
(16 DL650A) Let's ride!
Gogodammit is offline
Human Verification
