Had a weird problem with my V2. - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 13Likes
post #1 of 21 Old 02-13-2017, 10:11 AM Thread Starter
I was camping this weekend when I needed my tool kit.
The lock would accept key and try and turn, but it wouldn't turn either way. I can't remember which direction opens seat.
I've sprayed WD-40 in key hole, forcing key close to breaking point. I've had someone sit on seat, hit it with dead blow hammer, all to no affect.
I'm thinking my air hawk under seat might be holding cable or something???
Any advice would be greatly appreciated. Thank you.
2stroke is online now
post #2 of 21 Old 02-13-2017, 10:21 AM
Have someone sit on/beat on/cuss the seat while you hold pressure on the key. It is a clockwise turn to release on all V STroms I have had, but I don't have the new 1000's.
WERKS Quiet Ride windshields for 2012+ DL 650-transform your V strom. Nothing compares.
Have questions about the Quiet Ride or clutch in your DL or SV 1000? E-mail Terry info@werksparts.com
realshelby is offline
post #3 of 21 Old 02-13-2017, 10:34 AM Thread Starter
I tried that. Is there a way to access cable?
post #4 of 21 Old 02-13-2017, 12:14 PM
rgonaut's Avatar
I'm not sure man, is there any slack in your air hawk strap? would it be worth it to cut it and pull it out. It could be binding the cable.
rgonaut is offline
post #5 of 21 Old 02-13-2017, 12:16 PM Thread Starter
I can't get at it.
post #6 of 21 Old 02-13-2017, 12:20 PM
Bugzy's Avatar
See if this helps
Hanz and 2stroke like this.
Bugzy is offline
post #7 of 21 Old 02-13-2017, 01:43 PM Thread Starter
Thanks bugzy. I now know what I'm dealing with. I hate to drill a hole if I didn't have to. Wonder if I could pull plastic out a bit to get a screwdriver under plastic. I'm thinking a strap from airhawk worked its way under cable, so even if was to access that lever behind key hole, I would still need to clear obstruction at latch end.
SECoda likes this.
post #8 of 21 Old 02-13-2017, 02:08 PM Thread Starter
Maybe Greywolf has an idea. I might have to cut seat off and buy a new seat.
post #9 of 21 Old 02-13-2017, 04:16 PM Thread Starter
Originally Posted by Bugzy View Post
See if this helps
Thank you so much for that video Bugzy. After looking at cable placement, I was sure that the airhawk was the culprit.
Was able to pry back of seat up enough to get a coat hanger with a hook on it, and to grab enough of airhawk to get some needle nose pliers on the edge of it, and then my hand on it. Was able to yank it out through crack. That freed the cable.
That was super nice of you to shoot that video. Made all the difference. I owe you a drink.
Big B, Bugzy, Solo Moto and 4 others like this.
post #10 of 21 Old 02-13-2017, 05:45 PM
Motor7's Avatar
Now email Terry Adcox and place an order...no more Airhawk!
terryscustomseats
Big B and SECoda like this.
'15 DL650XT
Motor7 is online now
Human Verification
