Throttle Control or Electronic Cruise Control - Page 3 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 24Likes
post #21 of 35 Old 01-06-2017, 12:54 AM
sillyboy's Avatar
Originally Posted by Bugzy View Post
To disengage a throttle lock you have to pull the clutch and turn the throttle all the way forward at the same time, not so easy to do in a panic situation, like if a deer suddenly appears or a ladder is on the road or something..
With a kaoko you can just roll the throttle down or up with it engaged, it is just a friction lock.
Cruise control drives me crazy as nobody on the road drives a constant speed.and I am always turning it on and off. I have 2 rostra units sitting here and I am still fine with the kaoko.
My longest stretch on a bike has only been 6 hours straight, maybe I would feel differently if I rode some serious miles.
sillyboy is offline
post #22 of 35 Old 01-06-2017, 08:24 AM
Just as easy to turn off the electronic cruise control as it is to release the Kaoko. Easier to reset it than the Kaoko. I don't use either a throttle lock or cruise in heavy traffic, unless for just a quick picking of my nose....
Some highways allow you to have the cruise engaged for many, many miles at a time. This really keeps you more relaxed on long rides and keeps your speed even.
Anyone that has installed electronic cruise control or had a bike with OEM cruise will tell you that they don't want a bike without it again on any longer ride.
WERKS Quiet Ride windshields for 2012+ DL 650-transform your V strom. Nothing compares.
Have questions about the Quiet Ride or clutch in your DL or SV 1000? E-mail Terry info@werksparts.com
realshelby is online now
post #23 of 35 Old 01-06-2017, 10:06 AM
Motor7's Avatar
You might change your mind if you do a trip where you are in the saddle for 8ish hours a day for a month. Like RS said, having a constant speed set(mine is always 5 over the limit) on long runs actually allows you to focus on more threats(animals, debris, potholes, etc). With a throttle lock it is constant correction, which is a distraction....well unless you are on the Bonneville Salt flat. And I don't have to worry about hearing this......"Press hard, there are 5 copies"
'15 DL650XT
Motor7 is offline
post #24 of 35 Old 01-06-2017, 10:41 AM
Moderator++
To those who have never had a real electronic cruise control on your bike, disrespectfully, your opinion has no basis in comparison. I decided upon having a bike with ABS brakes and a real electronic cruise control that I'd never have a bike without either again.
realshelby likes this.
greywolf is online now
post #25 of 35 Old 01-06-2017, 02:59 PM
I have an Atlas throttle lock on my 650. Works fine and speed is easy to adjust, simply open or close the throttle. It also fits any bike so you can take it with you.
Google Atlas throttle lock
Swissmaxie is offline
post #26 of 35 Old 01-06-2017, 06:29 PM
drgracer's Avatar
Another big thumbs up for the Rostra CC. The installation wasn't that hard, but it was time consuming. Like others have said, it'll take the better part of a day to install. I really can't add anything else that hasn't already said.
09 Wee
light travels faster then sound - which explains why people appear to be bright until they speak
drgracer is offline
post #27 of 35 Old 01-06-2017, 06:46 PM
Moderator++
When I put the CC on my '07 Wee, I just figured it was the next thing I'd like to have at the time. It, an aftermarket windscreen and a better seat were the three main changes that made the bike a great touring mount. I didn't realize how important I would consider it until I had it and headed for the Rockies. When I got the Glee in '12, I rode it a couple of weeks to make sure it didn't have any warranty issues then took it apart to add all the stuff I learned I wanted to have from riding the Wee. Windscreen, seat and cruise control along with support for heated gear were the must have items.
post #28 of 35 Old 01-07-2017, 01:31 PM
MaddBaggins's Avatar
I'm currently using an Omni Cruise throttle lock. I really want CC. My right hand and wrist are pretty beat up and I believe CC would be a lot nicer.
2014 DL1000A - Hazel
1979 CT90 - BOH
1994 FZJ80 - Tortuga
MaddBaggins is offline
post #29 of 35 Old 01-07-2017, 01:54 PM
I see a lot of mention of Rostra. I didn't find any motorcycle specific on their site. Are people fitting the universal model to MC's?
1979 CT90 - BOH
post #30 of 35 Old 01-07-2017, 02:12 PM
ThatFixedIt's Avatar
Yes, use the universal one. Rostra does not support motorcycle installations, so you may be depending on this group for your main source of tech support. The good news is that there are some experienced competent installed here.
Sent from my SM-G930U using Tapatalk
2015 DL1000
2012 BMW K1600GTL
2009 DL650 (For Sale)
2009 Yamaha V-Star XVS950 (For Sale)
All with the required enhancements.
ThatFixedIt is offline
Human Verification
