Where did my shift lever go? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 15 Old 01-07-2013, 08:43 PM Thread Starter
Yes the Vee is a true value, it's a blast to ride. Let me start by saying my bike is out of warranty, it's an 05 with 2,200 miles on the clock, I bought it a couple of months back with 800 miles on the odometer! The bike looks showroom new and runs well, excepting the injection issue between 3-4k. Yesterday I went to change gears leaving a stop sign and my foot went to the pavement the shifter had vibrated free of bracket , no thread locking compound! The shifter is now safely back on the bike minus the first couple of threads in the bracket, they died when the lever broke free of the bracket. I am still elated with the bike, mine is black and I think it looks great, looks are subjective. If you haven't checked your shifter lately you might want to.
Mbradley is offline
post #2 of 15 Old 01-07-2013, 08:58 PM
I had the same thing, I think, happen to my 04 Wee. Got off the freeway and after the stop sign I was in first gear for the next 3 miles until I got home. The pivot bolt had undone itself. i just tightened it back up. Beware the use of f-ing locktite.
post #3 of 15 Old 01-07-2013, 09:05 PM
HeUeR's Avatar
A buddy of mine had the same thing happen to his 03.
https://www.youtube.com/watch?v=EeB5ZraUeYQ
HeUeR is offline
post #4 of 15 Old 01-07-2013, 09:11 PM
Moderator++
Suzy used thread locker on my '07 Wee. I'd recommend seing if it is easy to break free and using blue Loctite if it does.
greywolf is online now
post #5 of 15 Old 01-07-2013, 09:17 PM
ha ha.......had the same thing happen to my SV1000S about 30 minutes after I sold it to the new owner. They called me from the side of the interstate..........
http://www.easternvstromrally.com/
(make plans NOW if you have never attended....GREAT Event!!!)
mark444 is offline
post #6 of 15 Old 01-07-2013, 11:50 PM Thread Starter
Blue Loc-Tite
Grey Wolf, I definitely used the blue Loc-Tite on my bolt, I don't need that happening a second time, for those who may want to know, just in case threads need chasing you are looking at a # 10 in 1.25 thread. I simply ran a bolt back through from the opposite side of the footpeg bracket to clean up the threads, as I mentioned I am missing a few threads. I don't want to pay a dealer for a replacement bracket.
Mbradley is offline
post #7 of 15 Old 01-09-2013, 02:24 PM
Touratech to the rescue
This is the first thing I addressed. This is the ONLY TouraTech item I own.
Folding Shift Lever, Suzuki V-Strom DL1000 - Touratech-USA They also have them for the 650. Yes it is a bit pricey but at the time, 3 yrs 30K miles ago, it is the only one I could find. Gets rid of all that linkage to lube and adjust. JMHO.
Best of luck
~James
jtvisions is offline
post #8 of 15 Old 01-09-2013, 03:39 PM
Craig Jackman's Avatar
Best of luck
~James
After dealing with the same kind of linkage/sticky shifting/clean the pivot point issues and shift linkage falling off on the highway on the Kawi I had before the Vee, I jumped and got this at the first opportunity. HIGHLY recommended.
'03 DL1000 - "The Vee"
Mod list - Oxford heated overgrips. Garmin GPS w/Aquabox RAM mount. Mirror extenders. Givi V35 saddlebags, engine guards, and Kappa top box. Adventure Tech fork brace, wheel spacer, sidestand foot, and peg lowering kit. Gafler braided front brake & clutch lines. K&N air filter. Pyramid Fenda Extenda. GO Cruise throttle lock. Touratech folding shift lever. Rad guard. GSXR 4 piston brakes with SV Racing brackets. Yosh timing cover. SW Motech center stand and crossbar. Eastern Beaver headlight relay. 12 O'Clock Labs Speedo DRD. Werks clutch basket. Corbin seat.
Craig Jackman is offline
post #9 of 15 Old 01-09-2013, 04:26 PM
kenneth_moore's Avatar
My HD Shovelhead used to rattle parts off all the time. One year I rode home from Daytona with a pair of Vise-Grips for a shift lever. It wasn't that bad...
Go hakafugu yourself.
kenneth_moore is offline
post #10 of 15 Old 01-10-2013, 04:40 PM Thread Starter
Shifter Replacement
Guys, thanks for the heads up on this shifter replacement, I can't understand the thought process behind the original complicated design.
Mbradley is offline
Human Verification
