Best Place to Buy Battery Gauge? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 12-11-2012, 09:46 AM Thread Starter
scott1000's Avatar
Trying to find a source to order a Battery Voltage Gauge from to mount either on the Handle Bars or Dash somewhere. I keep coming up on the LED one that just has different color light that come on telling what the output is but I don't want that. I see these neat little digital ones that tell you exactly where you are via a number. Can someone point me in the right direction to buy one? We'll get to the which wires do we hook it up to as to not drain the battery after I find and order one
If you give a Moose a Muff..ler...
Its a Kid thing
Next time I'll put some effort into my username. This one sounds like a toilet Bowl cleaner or Treadmill, or..
scott1000 is offline
post #2 of 9 Old 12-11-2012, 03:18 PM
I'm assuming you're looking for a digital voltmeter that you can mount somewhere. I found these two on google.
2 Wire Blue DC 4.5-30V LED Panel digital display Voltage Meter Voltmeter By BuyinCoins - Amazon.com
Universal 2" 52mm Blue Digital LED Volt Voltmeter Gauge 0-15V
pb4ugoout is offline
post #3 of 9 Old 12-11-2012, 04:44 PM Thread Starter
scott1000's Avatar
Yes, the first was more like what I wanted to find. I ended up ordering one from Signal Dynamics after seeing it mentioned in another thread about a dieing battery. Its just a simple LED buld that changes color depending on Voltage.. Works for me I guess
Its a Kid thing
post #4 of 9 Old 12-11-2012, 05:06 PM
tmcgee's Avatar
There are a bunch of waterproof voltmeters on fleabay for about $5, shipped from Asia.
tmcgee is offline
post #5 of 9 Old 12-11-2012, 06:39 PM Thread Starter
scott1000's Avatar
I see and like a many of those but I like stuff quickly when possible. The signal dynamics one should do the trick. Its not as neat-o as some of the others but honestly this is already pretty neat for me just getting one. Just a warning light really- preventive measure
Its a Kid thing
post #6 of 9 Old 12-11-2012, 06:46 PM
tmcgee's Avatar
My last one (about two weeks ago) was received in two days from Hong Kong. Total charge was $5 and change.
tmcgee is offline
post #7 of 9 Old 12-11-2012, 06:48 PM Thread Starter
scott1000's Avatar
Seriously? Doooooooooooooooooohhhhhhhhhhhhhhh
Its a Kid thing
post #8 of 9 Old 12-26-2012, 05:36 PM Thread Starter
scott1000's Avatar
Handled.............
Its a Kid thing
post #9 of 9 Old 01-03-2013, 08:00 AM
Jeff Kushner's Avatar
I got one of those like Scott described, that changes color depending on the voltage. Be careful though, there are a couple of different range options. I drilled a 12mm hole in the side of the verticle piece of plastic next to the front fuel tank cover piece behind the handlebar. I also added a on/off switch for it( all my switches for aux lights, radar detector and battery light are mounted in that same removeable plastic piece covering the front tank bolt). The only problem with the LED type is that you can't see it in daylight without covering it with your hand.
I had my magnets come loose in my alternator last spring and reglued them so I was very worried about them coming loose again and wanted some warning that the alternator had failed after having to phone-a-friend when my bike died on a trip. The glue has held and I also have piece of mind....but I do wish it was easier to see in the day time.
jeff
Present only:
My VStrom 1000 K7
Stock bikes: a purple '74 RD350 in great shape, '72 H1, 1975 GT550, ,original 1975 H2 750 triple (purple of course), '73 CB350-given to GF Modified bikes: Fully ported 1974 H2 750(my go-fast), a scary fast '82 Yam 650Turbo running 18PSI, a '75 GT550 built up & ported, '75- H1 wrist-rocket. To-Restore list: '72 H1, 1-'75 H1, 1974 GT750 Latest COMPLETED: 1975 S1 Kaw 250 baby triple
Jeff Kushner is offline
Human Verification
