Battery died somewhat abruptly...what am I looking at? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 20 Old 12-09-2012, 11:26 PM Thread Starter
maximilian's Avatar
Angry Battery died somewhat abruptly...what am I looking at?
The battery has been spot on, never run down, and always kept "topped off". Yet, about three starts ago, out of the blue, I noticed it was clearly experiencing serious voltage drop when attempting to start the vee. Today, I drove to the store; and when I went to go home, it would not start. Not even close. Seems a bit more sudden than I'd expect, if it was just an old battery dying. Seemed to go from 90% to 20% in like one week.
So...after bump starting (yea, that's fun on a Vee) and heading home, I charged with the battery charger for an hour. Then, hooked the volt-meter up to see what was going on:
Not running- 12.5 volt
Idling- 12.3 volts
Running at 2,500 rpm- 12.9 volts (although one time I was able to get 14.4.....but on subsequent tries, never went above 12.9)
Assuming that pretty much all of those numbers are telling me the charging system is FUBAR .....what are your thought?
thanks much, as always!
Max
'06 KLR650
'78 CB750
'04 DL1000
maximilian is offline
post #2 of 20 Old 12-09-2012, 11:51 PM
Can you start the bike up and remove the battery while it is running to test the alternator? Maybe put the hazards on as well. This is coming from a mechanically challenged perspective, fwiw.
Yesler is offline
post #3 of 20 Old 12-09-2012, 11:53 PM
hi there,
had the same problem few weeks ago, exactly the same.
it looks like a charging problem. it can be the alternator or the regulator, in my case it was the alternator, it is pretty rare that the regulator goes bad but it is good idea to be sure before replacing the alternator,
some time bad alternator can cause a regulator failure as well
any way im not en expert, only telling you what happen to me and what i have been told
iyaronman is offline
post #4 of 20 Old 12-10-2012, 12:00 AM
LoneStrom's Avatar
Lost my stator at about 13,000 miles did pretty much the same thing.When your in there check the magnets on the rotor,they have been know to come lose!!.
There is a very good test on here to check your stator!!.
1990 Yamaha XT350
2012 Honda NC700X BDR express......
1994 GS500..DORA THE PURPLE EXPLORA
LoneStrom is offline
post #5 of 20 Old 12-10-2012, 04:58 AM
"""Can you start the bike up and remove the battery while it is running to test the alternator? Maybe put the hazards on as well. This is coming from a mechanically challenged perspective, fwiw. """"
damn sure way to fry every bit of electronics in the bike.
May have been a reasonable test in days of yore but once electronics made it to the auto scene not on your nellie.
Tom
stator and reg/rect for sure
tomrux is online now
post #6 of 20 Old 12-10-2012, 05:13 AM
ockerstrom's Avatar
Your charge rate generally won't kick up to the 14.4v mark while the battery is fully charged [which you did by putting it on the charger].
I'd be looking for loose connections as the most likely cause of the sudden loss of starting ability [battery terminals, connections at starter motor etc.].
Get the battery tested by an auto electrician, don't risk damaging the electrics by trying things you don't know about.
I know you said push starting the "vee" but is it a Vee or a Wee you own [haven't heard of too many Wee's having stator probs].
Ock. in Oz
Windsor (near enough)
NSW
Australia
ockerstrom is offline
post #7 of 20 Old 12-10-2012, 07:51 AM
Voltar's Avatar
I had a similar experience. A new battery was all I needed. Follow along here:
http://www.stromtrooper.com/dl-1000-...tery-line.html
Voltar is offline
post #8 of 20 Old 12-10-2012, 08:35 AM
CanadianFZ6's Avatar
You don't need to remove the battery to do a basic test of the alternator... A simple multimeter test across the bikes batt terminals at idle... Without electrical accessories the voltage should be above 13.4V or so if the alternator is outputting... Turn off the bike and the voltage should drop to about mid 12V or so...
2015 DL650AL5 in Blue
CanadianFZ6 is offline
post #9 of 20 Old 12-10-2012, 09:55 AM
Scott E. Bonds's Avatar
My battery died over night and acted the exact same way.
2007 Blue SuperVee 1000
2000 Red Honda XR 400r
Scott E. Bonds is offline
post #10 of 20 Old 12-10-2012, 09:59 AM
Moderator++
Never disconnect the battery from a running engine. It buffers charging current. Without it, the regulator/rectifier and even the onboard computer can be damaged.
greywolf is online now
Human Verification
