Mis-fire when hot - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 13 Old 12-02-2012, 05:48 PM Thread Starter
Question Mis-fire when hot
Gentlemen, I've been chasing a problem for a while. My 2008 DL1K runs great when it first starts up. But when it heats up to three bars the engine begins to mis-fire (cough, sneeze) through the air box. This happens most when I'm slowly moving through traffic at 45 mph or lower. Running above 4k rpm doesn't help as it seems to be related more to heat and a lightly loaded engine. At speed on the highway I don't have this problem. I've done a TPS check, a TBS, changed plugs & air cleaner. Bike runs smooth, it just has this annoying cough when the engine heats up. Any ideas?
"I'm out of smoke bombs, napalm, and I'm outta 22 bullets" -Si Robertson
royefam is offline
post #2 of 13 Old 12-02-2012, 06:37 PM
Banned
When warm the enrichening is stopped soo you have the lean condition
My spirit guide says you have the intake boot loose off your throttle body. Sometimes he's wrong so the usual TPS and Throttle body Syncing, should clear it up
richw is offline
post #3 of 13 Old 12-02-2012, 06:56 PM Thread Starter
Checked the boots, both seated. Already done TBS. This has been a problem for a while. Thanks for the reply, though.
royefam is offline
post #4 of 13 Old 12-02-2012, 07:11 PM
Moderator++
Some Vees seem to be just too lean in stock condition and need an external device or an EEprom rewrite to get a decent fuel map.
post #5 of 13 Old 12-02-2012, 08:12 PM Thread Starter
Grey, you really think this indicates a lean condition? I am using a Healtech FI Pro unit using their base map for the Two Brothers mufflers I am using. At speed this bike runs great. But in traffic at low speeds it mis-fires a lot.
royefam is offline
post #6 of 13 Old 12-02-2012, 08:19 PM
Moderator++
It sounds like you need to richen the low rpm range.
post #7 of 13 Old 12-02-2012, 08:23 PM Thread Starter
I'll give that a try, thanks.
royefam is offline
post #8 of 13 Old 12-02-2012, 08:50 PM
I have a PC111 and run two bros carbon cans. When he gets hot in traffic, 3 bars stuck in traffic for a while hot, when I try accelerating away, theres often a hesitation and sometimes it stalls. This only hppens when it is really hot. Everything else is fine and I'm running 95 fuel so thats not an issue. You might have the same issue. I am used to stopping my old BMW in traffic and have been doing this a bit and it does help a little when I can see the lights and be ready for quick start ups and go then stop it again. Otherwise I have to blip the throttle everynow and then especially before moving off, but its loud and I don't like doing it too much.Maybe theres a way to re map the beast when hot idle is happening. If so, please let me know as i'm no computer wizz!
2008 DL1000 - Two Bros cans, ProTaper Bar, Oxford Grips, PC111, Givi crash bars, MCA screen, bark busters, rad & bash guards.
1977 BMW R100S - SOLD
1984 BMW R80RT - Sold
1984 DR185 - Retired
timr is offline
post #9 of 13 Old 12-02-2012, 09:17 PM Thread Starter
I'm going to tweak the low end of my FI Pro map and see if that helps. If it does I'll let you know!
royefam is offline
post #10 of 13 Old 12-03-2012, 08:02 AM
Banned
TPS is a wear part
richw is offline
Human Verification
