Mis-fire when hot - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #11 of 13 Old 12-03-2012, 10:14 AM Thread Starter
I was going to enrich the lower end of my fuel map tonight. It won't take long to double check the TPS, so might as well, right? Now, what did I do with that jumper I made to go into service mode? I spent time last night and this morning looking for the programming cable to the FI Tuner Pro. We moved to a new city a few months ago and I'm still discovering where some things are!
"I'm out of smoke bombs, napalm, and I'm outta 22 bullets" -Si Robertson
royefam is offline
post #12 of 13 Old 12-03-2012, 10:29 AM
randyo's Avatar
Some Vees seem to be just too lean in stock condition and need an external device or an EEprom rewrite to get a decent fuel map.
My Vee wasn't one of those Vees, but things have changed since cancer surgery that replaced the wire harness and all the sensors
RandyO
IBA# 9560
07 Strom 1k (8x,xxx miles)
99 SV650 (135,006 miles)
82 XV920R
A man with a gun is a citizen
www.gbhsurvey.com
randyo is offline
post #13 of 13 Old 12-03-2012, 07:11 PM Thread Starter
Success
Thanks everyone. Been making small changes to the 2% to 5% throttle position part of my FI map and the mis-fire has already improved to a slight stumble. Even this is an improvement, but I think with a little more tweaking I should be able to clean up the stumble. Thanks for the encouragment.
royefam is offline
Human Verification
